Hitting the same problem. But I am not so sure if this is a nginx config problem when i query the internal rails address the same error pops up so i assume its just proxied forward by nginx(?)
We just had the same issue after updating to version 7, but were able to resolve it.
After updating our nginx config based on the example provided in /opt/zammad/contrib/nginx/zammad_ssl.conf, the site was back to normal.
Looking at the diff, the most probable cause was the missing root /opt/zammad/public; line.
Until now, everything was proxied, including the assets. Is it possible, that this changed with version 7 and static files have to be served from the docroot directly?
No, that section is in the config for quite some time:
Somehow I must have missed that during the initial setup. We never had this line in our nginx config and did not have any issues.
I just verified and the backend behaviour changed:
Version 6.5.2
$ curl http://localhost:3000/assets/form/form.js
(function ($) {
* provides feedback form for zammad
<button id="zammad-feedback-form">Feedback</button>
<script id="zammad_form_script" src="http://localhost:3000/assets/form/form.js"></script>
Version 7.0.0
<!DOCTYPE html>
<html class="dark">
<meta charset="utf-8">
<title>404: Not Found</title>
<link rel="stylesheet" href="/assets/error/style.css">
<body >
With this change, the line in the nginx config became crucial.
Iāve got the same error. Zammad is behind an external nginx reverse proxy.
@KH-Marco what was your error in the nginx config?
If you have two proxies chained, then itās technically a different error.
I donāt have two proxies. The nginx on the zammad host is stopped. The setup worked with 6.5.3 without any problems. Iāve set the proxy_http_version on the / location.
Maybe iām wrong - my proxy log drops a 404 for the assets. My production.log on the zammad host also says ānot foundā. If i use wget on the zammad host to get for instance http://172.16.x.x:3000/assets/images/icons.svg there is also a 404 error.
I assume youāre not using a package installationā¦? If so, please create an independent thread, because this one is about package only and otherwise will be very confusing for others finding this one.
I use the package installation with Debian 13. Maybe it makes a difference, that i installed the previous package version direct to Debian 13. I will test this with a fresh install and my proxy setup.
Iāve got my setup working with some changes to the reverse proxy nginx and the zammad host nginx:
I have the same issue. After the update from 6 to 7, I see only āLoadingā¦ā and nothing else. I use Caddy as a reverse proxy in front of Zammad (apache2/nginx are disabled).
Here is my Caddyfile, which works fine with Zammad 6.
myhost.mydomain {
@actual_name host myhost.mydomain
handle @actual_name {
# https://community.zammad.org/t/websocket-and-csrf-issues/15050/3
@websockets {
header Connection *Upgrade*
header Upgrade websocket
reverse_proxy @websockets localhost:6042
reverse_proxy localhost:3000 {
# https://community.zammad.org/t/csrf-token-verification-failed-and-session-invalid/15066
header_up Host {http.request.host}
header_up X-Forwarded-For {http.request.remote}
header_up X-Real-IP {http.request.remote}
header_up X-Forwarded-Proto https
header_up X-Forwarded-Ssl on
Yeah, no wonder, youāre not shipping the assets. Zammad doesnāt do that for you (anymore).
Canāt speak for caddy, but hereās how itās done in nginx - Iām sure youāll wrap your mind around it as caddy admin.
Thanks! I have adapted the Caddyfile accordingly. Still, I cannot log in. When I open āhttps://zammad.mycompany.euā, I see āLoadingā, then a blank page. Using the developers tools of my browser, I can see that /api/v1/signshow returns an HTML document with no content. It does not look like an reverse proxy issue. I will continue to investigate as soon as I have the opportunity.
