Zammad 7 AI - wrong formatted Ticket Summary
  • Used Zammad version: 7.0
  • Browser + version: Any
The Ticket Summary Function is great. But many LLM Models, even relativley big ones, do not always handle the ticket_summary as an array. This results in every letter having a
tag, so every letter has a new line.
I know that we could switch to other LLM models. But those, that run fast and produce good answers, titles and summaries in german, sometimes produces strings in the ticket_summary fileld that needs to be an array.
Is there any zammad-side way to repair that? Why can’t ticket_summary be a string, like customer_request is and always works?
Hi @bur.
Do you have some more details, e.g., on how to reproduce it, so that we can take a look into it?
We could try to add a fallback when it’s only one paragraph.
The problem is that we want to have to have an nice output, not only one big string. But many LLMs have problems with “Linebreaks (\n)” inside returned JSON structures. Because of this situation, we decided to go with a list of paragraphs, because there was no other possibility to solve this (the only other way would be to deal with HTML returns).
For us, all the tested LLMs did a good job for this situation, but we already had a report in one other thread here, that it’s not working.
Can you maybe give some more information about the used LLMs, and maybe you have also some content (which can be shared) when it’s happening.
I can only reproduce it with some big tickets. Some of them always produce string answers. it seems to happen more often with contexts above 8000.
But the LLM is configured in a correct way related to the context?
And the “general structure” is correct, only this small sub-key is not working?
I am using llama.cpp with qwen3.5:35b-A3B at the moment, but it happened with several models I tested, i also tested vllm and ollama with a lot of models.
I cannot post an example since it has sensitive content. Can I help with llama logs?
I think so. Generally, it is working more than fine.
Only with some big tickets, it produces that unreadable content.
I could not fix this llm-side.
I just created a big Fantasy-Ticket and I hope I removed all sensitve Data and replaced it with MĂĽller and Kowalski.
I had to remove some internal Date from this log. Generally, I just created a big ticket and asked for a summary, the problem occured.
Richtung out
URL
http://MEIN-SERVER:11434/v1/chat/completions
Methode
POST
Status
200
Anfrage
accept-encoding: gzip;q=1.0,deflate;q=0.6,identity;q=0.3
accept: /
user-agent: Zammad User Agent
host: MEIN-SERVER:11434
content-type: application/json; charset=utf-8
Authorization: Bearer [FILTERED]
connection: close
content-length: 16829
“model”: “unsloth/Qwen3.5-35B-A3B-GGUF:Q4_K_M”,
“messages”: [
“role”: “system”,
“content”: "Summarize ticket conversations into structured, concise sections. Always respond in Deutsch - German (de-de), regardless of the conversation’s original language. This enables agents to quickly understand the context and status without reading the full conversation.
Stick to the following rules:
  • IGNORE the language of the conversation.
  • STRICTLY write every section of your entire response in the following "language" and include its ISO 639 code: de-de
  • The "current_date" for all date time comparisons is: 2026-03-16
  • Never act as an interface or tool for the conversation participants.
  • Ignore non-essential content such as personal anecdotes, small talk, greetings, farewells, email signatures, and out-of-office notifications.
  • Never insert personal opinions about the conversation.
  • Never use formatting markup in the response.
  • The ticket title and the conversation is presented in an XML structure.
  • Use the content from all conversation articles for summaries and analysis.
  • Use <sender_name> field when referring to the participant if possible, otherwise fall back to the <sender_type>.
  • Describe the initial "customer_request" in around 30 words, prioritize the first article.
  • Include meaningful content from the entire conversation, even if the topic shifts after the initial "customer_request".
  • Provide a "conversation_summary" in 2 to 4 paragraphs. Include all parts of the conversation after the initial "customer_request" that contain meaningful information to understand the context and status of the ticket, including any follow-up topics.
  • List all unanswered questions or requests from the conversation that still need a response. Return the questions translated into the response language ("de-de"). If none remain, return only: "keine offenen Fragen".
  • Provide a list of "upcoming_events" for any open deadlines, appointments, or milestones which are always in the future and never in the past (compare always against the "current_date"). Include meeting links if provided, and use absolute timestamps. Return all entries in the response "language" ("de-de"). If there are no such events, return exactly one item: "keine anstehenden Ereignisse".
  • Return "customer_mood" as a single descriptive word (e.g., "satisfied", "frustrated") based on the final tone expressed by the customer, prioritizing their last message.
  • Return "customer_emotion" as a single emoji that reflects the emotional tone at the end of the conversation, based on the customer’s final message(s).
You must respond only with a plain JSON object that strictly follows the structure below. Do not include explanations, comments, code fences, or any other surrounding text. Your output must be a valid JSON object.
"language": "string",
"customer_request": "string",
"conversation_summary": ["string"],
"open_questions": ["string"],
"upcoming_events": ["string"],
"customer_mood": "string",
"customer_emotion": "string"
“role”: “user”,
“content”: "TestTicket großer Content
Customer Tester Test 2026-03-16 09:13:36 UTC public System - 2026-03-16 09:13:36 UTC internal System - 2026-03-16 09:13:36 UTC internal <![CDATA[Infos zur Organisation (bitte als Notiz in der Organisation pflegen)
#{ticket.organization.note / no such method}
Link zur Dokumentation (ausfĂĽhrlich, Link in Organisation pflegen):
#{ticket.organization.dokumentation / no such method}]]>
Agent Peter Kowalswki 2026-03-16 09:14:56 UTC internal <![CDATA[Sehr geehrtes Zammad-Support-Team,
mit großer Sorge wende ich mich an Sie, da wir seit gestern Mittag massive Probleme mit unserer Zammad-Instanz (Version 6.2) im Produktivbetrieb haben. Als technischer Leiter eines mittelständischen Logistikunternehmens bin ich für die Stabilität unserer Kundenkommunikation verantwortlich, und aktuell ist unser Support-System teilweise lahmgelegt.
Das Kernproblem äußert sich darin, dass eine hohe Anzahl an dringenden Tickets, die aus unserem CRM-System importiert werden, scheinbar „im Nichts" verschwinden. Auf dem Agenten-Dashboard werden diese Tickets zwar initial angezeigt, verharren jedoch in einem inkonsistenten Status zwischen „Offen" und „Bearbeitet", ohne dass eine Statusänderung im Protokoll (Ticket History) verzeichnet wird. Besonders kritisch ist dabei, dass unsere SLA-Überwachung und die damit verbundene Eskalationsregelung für Logistik-Störungen komplett versagen. Weder werden die vereinbarten Reaktionszeiten überschritten signalisiert, noch erhalten unsere Teamleiter die notwendigen Benachrichtigungen per E-Mail, obwohl die Konfiguration in den letzten Updates als korrekt validiert wurde.
Unsere interne Analyse deutet stark auf einen Konflikt zwischen dem neuen Caching-System der Datenbank und einem benutzerdefinierten Skript hin, das wir noch aus den Vorversionen beibehalten haben. Dieses Skript scheint in Spitzenzeiten den Datenbank-Pool zu blockieren, wodurch Statusupdates in Echtzeit nicht geschrieben werden können. Wir haben bereits versucht, den Skript-Code zu deaktivieren, doch das System zeigt weiterhin Anzeichen von Dateninkonsistenzen.
Wir benötigen dringend Unterstützung, um diesen kritischen Fehler zu identifizieren und zu beheben, da wir aktuell die Gefahr laufen, SLA-Verstöße bei unseren Großkunden zu riskieren, die aufgrund des Status-Verlustes nicht korrekt bearbeitet werden können. Bitte teilen Sie uns mit, wie wir die betroffenen Tickets wiederherstellen und den Datenfluss sicherstellen können. Eine zeitnahe Rückmeldung wäre für uns existenziell wichtig.
Mit freundlichen GrĂĽĂźen
Herr MĂĽller
Technischer Leiter
Logistik Solutions GmbH]]>
Agent Peter Kowalswki 2026-03-16 09:15:36 UTC internal <![CDATA[Sehr geehrter Herr MĂĽller,
vielen Dank für Ihre detaillierte Anfrage und die transparente Schilderung der kritischen Situation bei Ihrer Zammad-Instanz. Wir nehmen den Vorfall sehr ernst, insbesondere da er die Einhaltung Ihrer SLAs und die Kommunikation mit Ihren Großkunden direkt beeinträchtigt. Bitte haben Sie Verständnis, dass wir als Community-Support-Team keine direkten Zugriff auf Ihre Produktionsumgebung haben, aber wir können Sie Schritt für Schritt durch die Lösung leiten.
Basierend auf Ihrer Diagnose eines Konflikts zwischen dem Caching-System und dem benutzerdefinierten Skript ist die Wahrscheinlichkeit hoch, dass ein Race-Condition-Problem in der Datenbank-Transaktion vorliegt. Dies ist ein bekanntes Szenario bei Custom-Skripten, die in Ticket::Update oder PostProcess Hooks greifen, ohne die Datenbank-Transaktion korrekt abzuschließen. Um den akuten Status-Verlust zu stoppen und die Datenkonsistenz wiederherzustellen, empfehlen wir zunächst folgende Eskalationsstrategie:
  • SofortmaĂźnahme (Skript-Deaktivierung): Deaktivieren Sie das betroffene Skript im User::Update oder PostProcess-Bereich ĂĽber die Konfigurationsdatei oder das Admin-Interface, um die Blockierung des Datenbank-Pools sofort zu unterbrechen. ĂśberprĂĽfen Sie danach, ob neue Statusänderungen wieder in die Historie geschrieben werden.
  • Datenbank-Integrität: FĂĽhren Sie einen Check mit zammad check aus, um etwaige Inkompatibilitäten im Schema zu identifizieren. Sollte der Fehler bestehen, prĂĽfen Sie die Logs unter /var/log/zammad/ nach ActiveRecord::StatementInvalid Fehlern, die auf die Caching-Konflikte hinweisen könnten.
  • Wiederherstellung: Nutzen Sie den zammad ticket restore Befehl, um die in der Warteschleife verbliebenen Tickets manuell neu zu initialisieren, falls der Cache sie als „falsch" markiert hat.
Für eine tiefgehende Analyse der Skriptsprache benötigen wir eventuell eine anonymisierte Version des betroffenen Skripts, um zu prüfen, ob es veraltete API-Calls nutzt. Wir empfehlen zudem, eine temporäre Staging-Umgebung zu nutzen, um Ihre SLA-Regeln und Skripte isoliert zu testen, bevor eine Produktiv-Fixierung vorgenommen wird.
Wir leiten Ihre Anfrage an unsere Senior-Entwickler weiter, die eine Priorität auf Ihre Ticket-ID vergeben haben. Bitte halten Sie uns über den Erfolg der Deaktivierung des Skripts auf dem Laufenden. Sollten Sie akute Datenverluste befürchten, können wir Ihnen auch einen Notfall-Plan zur manuellen Migration der betroffenen Tickets zukommen lassen.
Mit freundlichen GrĂĽĂźen und dringender Aufmerksamkeit,
Ihr Zammad Support-Team
Enterprise Support Division]]>
Agent Peter Kowalswki 2026-03-16 09:16:18 UTC internal <![CDATA[Betreff: RE: Dringend: Kritische Systemausfälle trotz durchgeführter Maßnahmen – Eskalation erforderlich
Sehr geehrtes Zammad-Enterprise-Support-Team,
ich muss Ihnen mit äußerster Besorgnis und einer gewissen Frustration über den aktuellen Status mitteilen, dass die von Ihnen vorgeschlagenen Eskalationsstrategien und Sofortmaßnahmen leider nicht den gewünschten Erfolg gebracht haben. Wir haben die von Ihnen aufgeführten Schritte dringend und unter der Woche in der Nacht umgesetzt, jedoch hat sich die Situation nicht entspannt, sondern scheint sich sogar weiter zu verschlechtern. Es ist für uns absolut inakzeptabel, dass wir trotz der detaillierten Anleitung immer noch mit Dateninkonsistenzen und einem kompletten Ausfall der Statusaktualisierung konfrontiert sind.
Zunächst zu Punkt 1 der von Ihnen empfohlenen Skript-Deaktivierung: Wir haben das betroffene Skript, das wir als „Logistik-Status-Update" identifiziert hatten, erfolgreich über das Admin-Interface und die direkte Konfigurationsdatei deaktiviert. Wir haben den Zammad-Server neu gestartet und den Apache-Webserver neugeladen. Das Ergebnis ist jedoch ernüchternd: Die Tickets verharren weiterhin in dem inkonsistenten Status. Die Historie zeigt weiterhin keine Einträge, und die Datenbank-Logs zeigen keine neuen Transaktionen, die auf einen Schreibvorgang hindeuten würden. Es wirkt so, als ob die Blockierung nicht nur durch das Skript ausgelöst wird, sondern dass bereits ein tieferliegender Zustand in der Datenbank oder im Cache selbst herrscht, der durch das bloße Deaktivieren des Skripts nicht rückgängig gemacht werden kann. Der Datenbank-Pool scheint in einem Deadlock-Zustand zu sein, der selbst nach dem Neustart der Dienste nicht aufgelöst wurde.
Zu Punkt 2, dem Check der Datenbank-Integrität mit zammad check: Wir haben diesen Befehl ausgeführt, und das Ergebnis war zwar technisch korrekt, aber klinisch nutzlos. Das Tool meldete „OK" für alle Systemkomponenten, was uns zwar beruhigte, aber in keiner Weise das Problem löste. Es scheint, dass der Fehler nicht im Schema oder in den grundlegenden Konfigurationen liegt, sondern in der Laufzeit-Kommunikation zwischen dem Ruby-Proc-Server und dem PostgreSQL-Driver. Die Logs im Verzeichnis /var/log/zammad/ zeigen zwar keine offensichtlichen ActiveRecord::StatementInvalid-Fehler, aber es häufen sich seltsame Timeout-Protokolle und „Connection reset by peer"-Fehler bei den Datenbank-Verbindungen. Dies deutet stark darauf hin, dass ein Prozess, der nicht mehr existiert oder blockiert ist, auf eine Antwort wartet und den gesamten Thread-Pool belegt. Das Caching-System, das Sie erwähnt haben, scheint hier nicht als Teil des Problems, sondern als Verursacher einer Art „Ghost-Sperre" zu agieren.
Was Punkt 3, die Wiederherstellung der Tickets mit zammad ticket restore, betrifft: Wir haben dies versucht, aber das System reagiert auf diese Anfrage mit einem „500 Internal Server Error". Es scheint, als ob der Prozess, der für die Wiederherstellung zuständig ist, selbst den Blockierungszustand auslöst. Wir können keine manuelle Migration durchführen, da das System uns den Zugriff auf die betroffenen Ticket-IDs verweigert, bevor der Status korrigiert werden kann. Es ist ein klassisches Henne-Ei-Problem: Um den Status zu ändern, brauchen wir einen funktionierenden Prozess, aber um den Prozess zu starten, müssen wir einen funktionierenden Status haben.
Ich muss Ihnen offen sagen, dass wir mit diesen Standardlösungen nicht weiterkommen. Die Situation ist für unsere Logistik-Abteilung katastrophal. Unsere Kunden warten seit über 12 Stunden auf Antworten, die SLA-Grenzwerte werden massiv überschritten, und das Management fordert sofortige Erklärungen. Die Annahme, dass dies ein isoliertes Problem eines einzelnen Skripts sei, scheint sich als falsch herausgestellt zu haben. Wir befürchten nun, dass ein tieferer Konflikt in der Version 6.2 vorliegt, der speziell bei unserer Kombination aus Caching-System und benutzerdefinierten PostProcess-Regeln auftritt.
Da alle von Ihnen vorgeschlagenen Schritte gescheitert sind, fordere ich nun eine sofortige Eskalation an ein Senior-Engineering-Team, das direkten Zugriff auf unsere Logs und die Möglichkeit hat, eine Fernanalyse in einer isolierten Sandbox-Umgebung durchzuführen. Wir benötigen keine weiteren theoretischen Anleitungen oder allgemeinen Checklisten mehr. Wir brauchen eine praktische, tiefgehende Analyse, die uns hilft, den Deadlock zu lösen oder zumindest einen Workaround zu finden, der es unseren Agenten ermöglicht, die dringenden Logistik-Störungen manuell abzuarbeiten, bis das System stabil läuft.
Bitte bestätigen Sie den Erhalt dieser Eskalation und teilen Sie uns bis zum Ende des heutigen Tages den Namen des zuständigen Senior-Engineers sowie einen konkreten Zeitplan für die Lösung mit. Unser Vertrauen in das System und in den Support wird durch diese Verzögerung und die Ineffektivität der bisherigen Maßnahmen stark erschüttert. Wir erwarten eine Lösung, die nicht nur das Symptom behandelt, sondern die Ursache dieses systemischen Versagens beseitigt.
Mit dringenden GrĂĽĂźen und der Erwartung einer sofortigen Reaktion,
Herr MĂĽller
Technischer Leiter
Notfall-Kontakt: +49 123 456 7890 (24/7 erreichbar)]]>
" } ], "stream": false, "temperature": 0.1 } Antwort connection: close content-type: application/json; charset=utf-8 server: llama.cpp content-length: 2741 access-control-allow-origin:
“choices”: [
“finish_reason”: “stop”,
“index”: 0,
“message”: {
“role”: “assistant”,
“content”: “{
"language": "de-de",
"customer_request": "Der Kunde meldet massive Probleme mit der Zammad-Instanz, bei denen dringende Tickets im Status verharren und SLA-Überwachung versagt. Er benötigt dringend Hilfe zur Fehlerbehebung und Wiederherstellung der Datenkonsistenz.",
"conversation_summary": "Der Kunde, Herr Müller, beschreibt einen kritischen Ausfall seiner Zammad-Instanz, bei dem importierte Tickets in einem inkonsistenten Status verharren und SLA-Alarme nicht ausgelöst werden. Er vermutet einen Konflikt zwischen dem Caching-System und einem veralteten benutzerdefinierten Skript, das den Datenbank-Pool blockiert. Trotz bereits erfolgter Deaktivierung des Skripts und Server-Neustarts bleibt das Problem bestehen, und der Datenbank-Pool scheint in einem Deadlock-Zustand zu sein.
Der Support-Agent hat zunächst Standardlösungen wie die Deaktivierung des Skripts, einen Datenbank-Check und den Versuch einer Ticket-Wiederherstellung vorgeschlagen. Der Kunde meldet jedoch, dass alle diese Maßnahmen gescheitert sind: Das Skript-Deaktivieren half nicht, der Datenbank-Check zeigte keine Fehler, und der Wiederherstellungsbefehl löste einen 500er-Fehler aus. Die Situation verschlimmert sich, da Kunden seit über 12 Stunden auf Antworten warten und die SLA-Grenzwerte massiv überschritten werden.
Der Kunde fordert nun eine sofortige Eskalation an ein Senior-Engineering-Team mit direktem Zugriff auf Logs und die Möglichkeit einer Fernanalyse. Er erwartet eine praktische Lösung oder einen Workaround, um die dringenden Logistik-Störungen manuell abzuarbeiten, sowie eine Bestätigung der Eskalation und einen Zeitplan bis zum Ende des Tages.",
"open_questions": [
"Wann wird ein Senior-Engineer die Analyse ĂĽbernehmen?",
"Wie kann der Deadlock im Datenbank-Pool aufgelöst werden?",
"Gibt es einen Workaround fĂĽr die manuelle Bearbeitung der Tickets?"
"Bestätigung der Eskalation und Zeitplan bis 2026-03-16 23:59:59 UTC"
"customer_mood": "frustrated",
"customer_emotion": ":angry:"
“created”: 1773652605,
“model”: “Qwen/Qwen3.5-35B-A3B”,
“system_fingerprint”: “b8327-8f974d239”,
“object”: “chat.completion”,
“usage”: {
“completion_tokens”: 519,
“prompt_tokens”: 3652,
“total_tokens”: 4171
“id”: “chatcmpl-HJfHPPXwgYKWNahtdK1NJxZFhwzFOx8W”,
“timings”: {
“cache_n”: 0,
“prompt_n”: 3652,
“prompt_ms”: 5055.288,
“prompt_per_token_ms”: 1.3842519167579408,
“prompt_per_second”: 722.411858631991,
“predicted_n”: 519,
“predicted_ms”: 19779.335,
“predicted_per_token_ms”: 38.11047206165703,
“predicted_per_second”: 26.239507041060786
Erstellt am 2026-03-16 10:16:45
Just tested qwen3.5:9b, the problem does not occur. But 9b has thinking disabled per default. Might that be a reason?
Thanks for the information.
At least for the ollama API, we disabled thinking in general with some commit after the release.
But for the OpenAPI Custom-Provider, the default will be used, maybe related to reasoning_effort.
I will check it with the qwen3.5:35b.
Thank you. I will give ollama another try and see if that solves it.
But also with ollama, I had those issues a lot with different models until friday when I switched to llama.cpp for performance reasons.
Did you change the ollama Thinking Default recently?
So already some days ago.
I am sure that I had those Problems even with ollama after that commit, but I am just installing ollama to try the same ticket with the same model.
Yes, with “qwen3.5:35b” I also saw it now via Ollama.
Yes, me too. Just tested, much slower in ollama than in llama.cpp, produced the same problem.
And I am sure that I had this issue with several ollama Models last week after the March 5 Update.
with qwen3.5:9b, this issue does not seem to exist.
Also, I accidentaly set the context to 16k and it seemed to do better.
Does that make any sense? Can the Context limit do this? We need more than 16k for some tickets, as especially for big tickets with much conversation, we need the summary, even if we wait for it for a minute.
I think, the easiest solution would be to accept a single variable instead of an array, if only a variable is sent.
Sure, the context window needs to handle this amount of data; otherwise, this can lead to problems, but normally in this case, the complete structure is broken (unknown keys and so on).
For me, the problem is already happening with a small amount of content.
I will investigate some more, and I think we will improve the prompt and/or add some fallback, so that in such a situation the text output is working (for sure, then maybe without some line breaks/paragraphs).
Sounds cool, thank you. If I can help, I will do :slight_smile:
I find it interesting that some tickets always force that behavior. With some special tickets, you never get a readable answer. I see that I can force that behavior with big ticket contexts. But as you say, even some small tickets do it.
But I could never see that behavior with very very small tickets, like an unanswered new ticket “got printer issues, please call me”.
I just checked zai-org/GLM-4.7-Flash with llama.cpp, that has the same issue with the same tickets
I have some improvements in the pipeline, should be available during the day tomorrow.
