Zammad 6: Opensearch instead of Elasticsearch - Zammad 6 refuses
I have tried to run Zammad 6 with OpenSearch, so far un successfully.
Configured OpenSearch 2.9.0 (also tested 2.8.0) and Zammad 6.0.0-1690378408.79860681.bookworm.
I configured OpenSearch to pretend it is ElasticSearch, according to this post:
$ grep compatibility /etc/opensearch/opensearch.yml
compatibility.override_main_response_version: true
OpenSearch is up and available. But if I try to have Zammad talk to OpenSearch, Zammad aborts:
$ zammad run rake zammad:searchindex:rebuild
rake aborted!
Unable to process GET request to elasticsearch URL 'http://localhost:9200'. Check the response and payload for detailed information:
Response:
#<UserAgent::Result:0x00007f32ac69ff10 @success=false, @body=nil, @data=nil, @code=0, @content_type=nil, @error="#<EOFError: end of file reached>", @header=nil>
Payload:
null
Payload size: 0M
/opt/zammad/lib/search_index_backend.rb:36:in `info'
/opt/zammad/lib/tasks/zammad/search_index_es.rake:64:in `block (3 levels) in <main>'
/opt/zammad/vendor/bundle/ruby/3.1.0/gems/rake-13.0.6/exe/rake:27:in `<top (required)>'
/opt/zammad/bin/bundle:121:in `load'
/opt/zammad/bin/bundle:121:in `<main>'
Tasks: TOP => zammad:searchindex:rebuild => zammad:searchindex:version_supported
So, is anybody running Zammad version 6 with OpenSearch? What did you have to do?
Thanks.
Hi @alfredosola. OpenSearch is not supported right now.
I played around with it yesterday evening, but there are some changes needed in the code.
OpenSearch is made to be compatible with ElasticSearch. It works perfectly fine after setting
With this setting, OpenSearch reports the version number as it would be ES.
Also mentioned here:
This is an interesting observation because we had it running with Zammad 5 and now it works with Zammad 6. What did you find in your analysis?
@sebix> I set compatibility.override_main_response_version: true and afterward the command to create the needed pipelines failed. :person_shrugging:
Is your opensearch actually listening on http://localhost:9200 correctly?
Yeah, I checked that twice.
If the version check failed, the error message would be different, but yours is:
@body=nil, @data=nil, @code=0 ... @error="#<EOFError: end of file reached>", @header=nil>
All that suggests an empty response and that puzzles me. Are username/password in OpenSearch and Zammad set correctly (the same)?
What is the result of curl -X GET https://localhost:9200 -u '$user:$pass' --insecure (fill in the configured username/password combination, standard is admin/admin)?
For me on a working installation the result of the request is
  "name" : "openslides-zammad",
  "cluster_name" : "opensearch",
  "cluster_uuid" : "B7rcTWEoQDW6KO9Hyg_I9w",
  "version" : {
    "number" : "7.10.2",
    "build_type" : "deb",
    "build_hash" : "db90a415ff2fd428b4f7b3f800a51dc229287cb4",
    "build_date" : "2023-06-03T06:22:11.808047829Z",
    "build_snapshot" : false,
    "lucene_version" : "9.6.0",
    "minimum_wire_compatibility_version" : "7.10.0",
    "minimum_index_compatibility_version" : "7.0.0"
  "tagline" : "The OpenSearch Project: https://opensearch.org/"
Make sure you are talking the right protocol. I think the .deb package published by OpenSearch (not sure if this is the default everywhere) talks https out of :9200, but by default Zammad expects http.
Then zammad run rails r "Setting.set('es_url', 'https://localhost:9200')" helps.
You’re mixing up things here. :slight_smile:
I was not talking about end of file reached etc., this was @alfredosola initial post I guess.
The error I saw was really related to creating the needed pipeline for attachments, this fails.
Ah, okay. Isn’t the creation of pipelines included in zammad:searchindex:rebuild? What error did you get?
This is what the latest run showed:
# zammad run rake zammad:searchindex:rebuild
Dropping indexes... done.
Deleting pipeline... done.
Creating indexes... done.
Creating pipeline... done.
Reloading data...
  - Chat::Session...
    done in 0 seconds.
  - Cti::Log...
    done in 0 seconds.
  - Group...
    done in 0 seconds.
  - KnowledgeBase::Answer::Translation...
    done in 8 seconds.
  - KnowledgeBase::Category::Translation...
    done in 0 seconds.
  - KnowledgeBase::Translation...
    done in 0 seconds.
  - Organization...
    done in 8 seconds.
  - StatsStore...
    done in 0 seconds.
  - Ticket::Priority...
    done in 0 seconds.
  - Ticket::State...
    done in 0 seconds.
  - Ticket...
    done in 1044 seconds.
  - User...
    done in 39 seconds.
@sebix> … after a restart of my OpenSearch Docker container it works. Thx for your help :smiley:
FWIW: I have also run the complete Zammad CI test suite against OpenSearch and it succeeded:
(using GitHub - sebix/zammad at opensearch and GitHub - sebix/zammad-docker-compose at opensearch, no modifications in the code, only in the tests)
It’s also important to install the needed ingest-attachment plugin in OpenSearch.
Of course. That’s equivalent like with ES:
/usr/share/opensearch/bin/opensearch-plugin install ingest-attachment
ES8 doesn’t need the ingest-attachment anymore. Is there also an OS version like that?
