Zammad 6.5 – Search Index Fails on Elasticsearch OSS 7.10.2 Due to flattened Field Type
  • Used Zammad version: 6.5.0
  • Used Zammad installation type: (source, package, docker-compose, …) package (APT on Ubuntu 22.04)
  • Operating system: Ubuntu 22.04 LTS
  • Browser + version: Firefox 126 / Chrome 126 (any modern browser – N/A for issue)
  • Zammad should rebuild the search index successfully using Elasticsearch OSS 7.10.2, as it falls within the supported version range (>= 7.8, < 9) listed in the documentation.
  • Running zammad run rake zammad:searchindex:rebuild fails with:
  • No handler for type [flattened] declared on field [preferences]
Full error indicates:
  • mapper_parsing_exception
  • Elasticsearch OSS 7.10.2 does not support flattened field type
    • Install Zammad via APT (apt install zammad) on Ubuntu 22.04
  • Use Elasticsearch OSS 7.10.2 as the search backend (default port 9200)
  • Upgrade to Zammad 6.5
  • Run:
Additional Notes:
Zammad’s documentation states support for Elasticsearch >= 7.8, but does not clarify that flattened requires either:
  • OpenSearch 2.5+, or
  • Official (non-OSS) Elasticsearch builds
This leads to unexpected failures for users running OSS 7.10.2 — which was the only free version after Elastic changed its license.
Would be great to:
  • Clarify OSS vs official build compatibility in docs
  • Warn about flattened dependency in upgrade notes
  • Consider making flattened optional/fallback to object
Thanks!
