Zammad 6.1 elasticsearch reindex fails
  • Used Zammad version: 6.1.0-1697709472.5c85a2c9.centos7
  • Operating system: CentOS 7
  • Browser + version: Arc (chrome engine, latest version)
  • Elasticsearch Version: 8.10.4
  • Index rebuild
[root@zammad elasticsearch]# zammad run rake zammad:searchindex:rebuild --trace
** Invoke zammad:searchindex:rebuild (first_time)
** Invoke zammad:searchindex:version_supported (first_time)
** Invoke zammad:searchindex:configured (first_time)
** Execute environment
** Execute zammad:searchindex:configured
** Execute zammad:searchindex:version_supported
** Execute zammad:searchindex:rebuild
** Execute zammad:searchindex:drop
Dropping indexes... done.
** Execute zammad:searchindex:drop_pipeline
Deleting pipeline... done.
** Execute zammad:searchindex:create
Creating indexes... rake aborted!
NoMethodError: undefined method '[]' for nil:NilClass
    settings = Setting.get('es_model_settings')[model.name] || {}
/opt/zammad/lib/search_index_backend.rb:853:in `model_settings'
/opt/zammad/lib/search_index_backend.rb:891:in `block in create_index'
/opt/zammad/lib/search_index_backend.rb:885:in `each'
/opt/zammad/lib/search_index_backend.rb:885:in `create_index'
/opt/zammad/lib/tasks/zammad/search_index_es.rake:17:in `block (3 levels) in <main>'
/opt/zammad/vendor/bundle/ruby/3.1.0/gems/rake-13.0.6/lib/rake/task.rb:281:in `block in execute'
/opt/zammad/vendor/bundle/ruby/3.1.0/gems/rake-13.0.6/lib/rake/task.rb:281:in `each'
/opt/zammad/vendor/bundle/ruby/3.1.0/gems/rake-13.0.6/lib/rake/task.rb:281:in `execute'
/opt/zammad/lib/tasks/zammad/search_index_es.rake:59:in `block (3 levels) in <main>'
/opt/zammad/vendor/bundle/ruby/3.1.0/gems/rake-13.0.6/lib/rake/task.rb:219:in `block in invoke_with_call_chain'
/opt/zammad/vendor/bundle/ruby/3.1.0/gems/rake-13.0.6/lib/rake/task.rb:199:in `synchronize'
/opt/zammad/vendor/bundle/ruby/3.1.0/gems/rake-13.0.6/lib/rake/task.rb:199:in `invoke_with_call_chain'
/opt/zammad/vendor/bundle/ruby/3.1.0/gems/rake-13.0.6/lib/rake/task.rb:188:in `invoke'
/opt/zammad/vendor/bundle/ruby/3.1.0/gems/rake-13.0.6/lib/rake/application.rb:160:in `invoke_task'
/opt/zammad/vendor/bundle/ruby/3.1.0/gems/rake-13.0.6/lib/rake/application.rb:116:in `block (2 levels) in top_level'
/opt/zammad/vendor/bundle/ruby/3.1.0/gems/rake-13.0.6/lib/rake/application.rb:116:in `each'
/opt/zammad/vendor/bundle/ruby/3.1.0/gems/rake-13.0.6/lib/rake/application.rb:116:in `block in top_level'
/opt/zammad/vendor/bundle/ruby/3.1.0/gems/rake-13.0.6/lib/rake/application.rb:125:in `run_with_threads'
/opt/zammad/vendor/bundle/ruby/3.1.0/gems/rake-13.0.6/lib/rake/application.rb:110:in `top_level'
/opt/zammad/vendor/bundle/ruby/3.1.0/gems/rake-13.0.6/lib/rake/application.rb:83:in `block in run'
/opt/zammad/vendor/bundle/ruby/3.1.0/gems/rake-13.0.6/lib/rake/application.rb:186:in `standard_exception_handling'
/opt/zammad/vendor/bundle/ruby/3.1.0/gems/rake-13.0.6/lib/rake/application.rb:80:in `run'
/opt/zammad/vendor/bundle/ruby/3.1.0/gems/rake-13.0.6/exe/rake:27:in `<top (required)>'
/opt/zammad/vendor/bundle/ruby/3.1.0/bin/rake:25:in `load'
/opt/zammad/vendor/bundle/ruby/3.1.0/bin/rake:25:in `<top (required)>'
/opt/zammad/vendor/ruby-3.1.3/lib/ruby/3.1.0/bundler/cli/exec.rb:58:in `load'
/opt/zammad/vendor/ruby-3.1.3/lib/ruby/3.1.0/bundler/cli/exec.rb:58:in `kernel_load'
/opt/zammad/vendor/ruby-3.1.3/lib/ruby/3.1.0/bundler/cli/exec.rb:23:in `run'
/opt/zammad/vendor/ruby-3.1.3/lib/ruby/3.1.0/bundler/cli.rb:486:in `exec'
/opt/zammad/vendor/ruby-3.1.3/lib/ruby/3.1.0/bundler/vendor/thor/lib/thor/command.rb:27:in `run'
/opt/zammad/vendor/ruby-3.1.3/lib/ruby/3.1.0/bundler/vendor/thor/lib/thor/invocation.rb:127:in `invoke_command'
/opt/zammad/vendor/ruby-3.1.3/lib/ruby/3.1.0/bundler/vendor/thor/lib/thor.rb:392:in `dispatch'
/opt/zammad/vendor/ruby-3.1.3/lib/ruby/3.1.0/bundler/cli.rb:31:in `dispatch'
/opt/zammad/vendor/ruby-3.1.3/lib/ruby/3.1.0/bundler/vendor/thor/lib/thor/base.rb:485:in `start'
/opt/zammad/vendor/ruby-3.1.3/lib/ruby/3.1.0/bundler/cli.rb:25:in `start'
/opt/zammad/vendor/ruby-3.1.3/lib/ruby/gems/3.1.0/gems/bundler-2.3.26/libexec/bundle:48:in `block in <top (required)>'
/opt/zammad/vendor/ruby-3.1.3/lib/ruby/3.1.0/bundler/friendly_errors.rb:120:in `with_friendly_errors'
/opt/zammad/vendor/ruby-3.1.3/lib/ruby/gems/3.1.0/gems/bundler-2.3.26/libexec/bundle:36:in `<top (required)>'
/opt/zammad/bin/bundle:121:in `load'
/opt/zammad/bin/bundle:121:in `<main>'
Tasks: TOP => zammad:searchindex:rebuild
  • zammad run rake searchindex:rebuild --trace
What I’m missing? Maybe anyone can help me?
Hi @giuliano. Your system is not up-to-date in regards to needed migrations. What’s the output of zammad run rails r 'ActiveRecord::Migration.check_pending!?
Running /opt/zammad/contrib/packager.io/postinstall.sh should do the trick for you.
