- Used Zammad version: 6.1.0-1699563276.d63911c3.jammy
- Used Zammad installation type: package (i think)
- Operating system: Ubuntu
- Browser + version: Mobile Safari
- Ability to use new mobile view to manage tickets
- Can view tickets but has connection lost to server in top right hand corner
- Unable to edit any ticket info eg: add reply or view / change status of ticket - Recieve a spinning whele that never finishes loading.
I was running version 5.4 and recetly upgraded to version 6.1
I have an external Apache Reverse Proxy that is applying a CA SSL Cert and directing all traffic to the zammad server
After reading through the forum I believe i have issues with the websockets and that they may have not worked at all adn it was falling back to another method.
I have tried pointing the ws:// with ports 80, 443, and 6042
http_type is set to https
fqdn is set to helpdesk.xxxxx
On my desktop i can see a websocket connection error in chrome developer tools
- websocket connection to wss://helpdesk.xxxxx/ws failed
- websocket connection to wss://helpdesk.xxxxx/ws:6042/ failed
I have tried multiple different settings that I have found throughout the forum but I am unable to get it to work.
I hope that i have been able to provide enough info and that it makes sense!
Thanks in Advance for your help, it is really appreciated!!
External Apache Reverse Proxy Config
<VirtualHost *:80>
ServerName helpdesk.xxxx
Redirect permanent / https://helpdesk.xxxxxxx
</VirtualHost>
<VirtualHost *:443>
SSLEngine on
SSLProxyEngine off
RequestHeader Set X-Forwarded-Proto: "https"
SSLCertificateFile /etc/apache2/ssl/cert2023.crt
SSLCertificateKeyFile /etc/apache2/ssl/key.pem
SSLCertificateChainFile /etc/apache2/ssl/ca.crt
ServerName helpdesk.xxxxxxx
ErrorLog ${APACHE_LOG_DIR}/error.log
CustomLog ${APACHE_LOG_DIR}/access.log combined
ProxyRequests Off
ProxyPreserveHost on
ProxyPass /ws ws://172.22.40.241/
ProxyPass /cable ws://172.22.40.241:3000/cable
ProxyPass / http://172.22.40.241/
/VirtualHost>
Internal Apache Config /etc/apache2/sites-available/zammad.conf
<VirtualHost *:80>
## don't loose time with IP address lookups
HostnameLookups Off
## needed for named virtual hosts
UseCanonicalName Off
## configures the footer on server-generated documents
ServerSignature Off
ProxyRequests Off
ProxyPreserveHost On
<Proxy 127.0.0.1:3000>
Require local
</Proxy>
ProxyPass /assets !
ProxyPass /favicon.ico !
ProxyPass /apple-touch-icon.png !
ProxyPass /robots.txt !
# legacy web socket server
ProxyPass /ws ws://127.0.0.1:6042/
# action cable
ProxyPass /cable ws://127.0.0.1:3000/cable
ProxyPass / http://127.0.0.1:3000/
RequestHeader set X_FORWARDED_PROTO 'https'
DocumentRoot "/opt/zammad/public"
<Directory />
Options FollowSymLinks
AllowOverride None
</Directory>
<Directory "/opt/zammad/public">
Require all granted
</Directory>
</VirtualHost>
