Zammad 6.1.0 run rake searchindex:rebuild fails
  • Used Zammad version: 6.1.0-alpha-1686728317.30ea2c30.bionic
  • Browser + version: Edge
  • Index rebuild
root@zammadnec:/home/administrator# zammad run rake searchindex:rebuild --trace
rake aborted!
Don't know how to build task 'searchindex:rebuild' (See the list of available tasks with `rake --tasks`)
/opt/zammad/vendor/bundle/ruby/3.1.0/gems/rake-13.0.6/lib/rake/task_manager.rb:59:in `[]'
/opt/zammad/vendor/bundle/ruby/3.1.0/gems/rake-13.0.6/lib/rake/application.rb:159:in `invoke_task'
/opt/zammad/vendor/bundle/ruby/3.1.0/gems/rake-13.0.6/lib/rake/application.rb:116:in `block (2 levels) in top_level'
/opt/zammad/vendor/bundle/ruby/3.1.0/gems/rake-13.0.6/lib/rake/application.rb:116:in `each'
/opt/zammad/vendor/bundle/ruby/3.1.0/gems/rake-13.0.6/lib/rake/application.rb:116:in `block in top_level'
/opt/zammad/vendor/bundle/ruby/3.1.0/gems/rake-13.0.6/lib/rake/application.rb:125:in `run_with_threads'
/opt/zammad/vendor/bundle/ruby/3.1.0/gems/rake-13.0.6/lib/rake/application.rb:110:in `top_level'
/opt/zammad/vendor/bundle/ruby/3.1.0/gems/rake-13.0.6/lib/rake/application.rb:83:in `block in run'
/opt/zammad/vendor/bundle/ruby/3.1.0/gems/rake-13.0.6/lib/rake/application.rb:186:in `standard_exception_handling'
/opt/zammad/vendor/bundle/ruby/3.1.0/gems/rake-13.0.6/lib/rake/application.rb:80:in `run'
/opt/zammad/vendor/bundle/ruby/3.1.0/gems/rake-13.0.6/exe/rake:27:in `<top (required)>'
/opt/zammad/vendor/bundle/ruby/3.1.0/bin/rake:25:in `load'
/opt/zammad/vendor/bundle/ruby/3.1.0/bin/rake:25:in `<top (required)>'
/opt/zammad/vendor/ruby-3.1.3/lib/ruby/3.1.0/bundler/cli/exec.rb:58:in `load'
/opt/zammad/vendor/ruby-3.1.3/lib/ruby/3.1.0/bundler/cli/exec.rb:58:in `kernel_load'
/opt/zammad/vendor/ruby-3.1.3/lib/ruby/3.1.0/bundler/cli/exec.rb:23:in `run'
/opt/zammad/vendor/ruby-3.1.3/lib/ruby/3.1.0/bundler/cli.rb:486:in `exec'
/opt/zammad/vendor/ruby-3.1.3/lib/ruby/3.1.0/bundler/vendor/thor/lib/thor/command.rb:27:in `run'
/opt/zammad/vendor/ruby-3.1.3/lib/ruby/3.1.0/bundler/vendor/thor/lib/thor/invocation.rb:127:in `invoke_command'
/opt/zammad/vendor/ruby-3.1.3/lib/ruby/3.1.0/bundler/vendor/thor/lib/thor.rb:392:in `dispatch'
/opt/zammad/vendor/ruby-3.1.3/lib/ruby/3.1.0/bundler/cli.rb:31:in `dispatch'
/opt/zammad/vendor/ruby-3.1.3/lib/ruby/3.1.0/bundler/vendor/thor/lib/thor/base.rb:485:in `start'
/opt/zammad/vendor/ruby-3.1.3/lib/ruby/3.1.0/bundler/cli.rb:25:in `start'
/opt/zammad/vendor/ruby-3.1.3/lib/ruby/gems/3.1.0/gems/bundler-2.3.26/libexec/bundle:48:in `block in <top (required)>'
/opt/zammad/vendor/ruby-3.1.3/lib/ruby/3.1.0/bundler/friendly_errors.rb:120:in `with_friendly_errors'
/opt/zammad/vendor/ruby-3.1.3/lib/ruby/gems/3.1.0/gems/bundler-2.3.26/libexec/bundle:36:in `<top (required)>'
/opt/zammad/bin/bundle:121:in `load'
/opt/zammad/bin/bundle:121:in `<main>'
root@zammadnec:/home/administrator# rake --tasks --trace
rake aborted!
No Rakefile found (looking for: rakefile, Rakefile, rakefile.rb, Rakefile.rb)
/usr/share/rubygems-integration/all/gems/rake-13.0.6/lib/rake/application.rb:705:in `raw_load_rakefile'
/usr/share/rubygems-integration/all/gems/rake-13.0.6/lib/rake/application.rb:104:in `block in load_rakefile'
/usr/share/rubygems-integration/all/gems/rake-13.0.6/lib/rake/application.rb:186:in `standard_exception_handling'
/usr/share/rubygems-integration/all/gems/rake-13.0.6/lib/rake/application.rb:103:in `load_rakefile'
/usr/share/rubygems-integration/all/gems/rake-13.0.6/lib/rake/application.rb:82:in `block in run'
/usr/share/rubygems-integration/all/gems/rake-13.0.6/lib/rake/application.rb:80:in `run'
/usr/share/rubygems-integration/all/gems/rake-13.0.6/exe/rake:27:in `<top (required)>'
/usr/bin/rake:25:in `load'
/usr/bin/rake:25:in `<main>'
  • zammad run rake searchindex:rebuild --trace
I upgraded everything, following step by step. Have Elasticsearch’s latest version 8.9.2
But I cant get a correct interpretation of the error. Can you help me with what I’m missing?
Well well, It’s working now.
The command is incorrect, in the docs Step 3: Connect Zammad says that the command is:
zammad run rake zammad:searchindex:rebuild
instead of
zammad run rake searchindex:rebuild (I was using this one)
Now it’s working:
Source;
Set up Elasticsearch — Zammad documentation
