- Used Zammad version: 7.0
- Used Zammad installation type: (source, package, docker-compose, …) : RPM
- Operating system: AlmaLinux 9
- Browser + version: Opera
We are installing Zammad from RPMs (on AlmaLinux). For this we have been using for years a mirror of the YUM repository (https://go.packager.io/srv/rpm/zammad/zammad/stable/el/9/$basearch/) made/maintainted with
reposync. -
A cron is running
reposyncdaily and the new RPMs appears as they are added to the repository
- Since 6.5.2 (we are late to upgrade…), the RPMs retrieved by
reposyncno longer have the usual file name pattern (.e.g.zammad-6.5.2-1762852784.1ff2c52d.centos9.x86_64.rpm) but a strange name (e.g.fe626d72-affe-5281-a306-4d765cb64cab.rpm). - If I use a
dnf info zammadagainst the upstream repository, it works as expected: it displays the proper RPM name (zammad), version 7.2.2, … but I don’t know how to access older versions (as if I’m right, I need to install 7.0 first before installing 7.2.2).
Any idea what we could have made wrong?
Thanks in advance for any hint
