Used Zammad installation source: github zammad-docker
Operating system: ubuntu / debian
Browser + version: Firefox
I have recently installed a new Zammad platform but if I access the statistics area I get a message in the center of the page with the error “X Elasticsearch need to be configured!”.
In the previous installation I got the same message but I performed a reconstruction of the registry found in a post on the community, that problem was solved and it was no longer possible to view the personal data of the users.
Hi, I have installed and configured elasticsearch coem you suggested but I still have problems.
I think the problem is due to the configuration of es_url.
If I disable it with the command zammad run rails r “Setting.set (‘es_url’, ‘’)” I can see the users in the settings but in the statistics the message "Elasticsearch need to be configured! " canteens if I set es_url, with the command “zammad run rails r” Setting.set (‘es_url’, ‘http: // localhost: 9200’) “” I don’t see the users and I get “Status code 500” on the statistics and the following message error “{” error “:” Unable to process GET request to elasticsearch URL 'http: // localhost: 9200 / zammadsrv_zammad_production / Ticket / search’. Elasticsearch is not reachable, probably because it’s not running or even installed. \ N \ nResponse: \ n # \ u003cUserAgent :: Result: 0x000055900c6418f0 @ success = false, @ body = nil, @ data = nil, @ code = 0, @ content_type = nil, @error = \ “# \ u003cErrno :: ECONNREFUSED: Failed to open TCP connection to localhost: 9200 (Connection refused - connect (2) for \” localhost \\ "port 9200) \ u003e " \ u003e \ n \ nPayload: \ n {\ "query ": {\ "bool ": {\ "must ": [{\ "range ": {\ "created_at ": {\ "from \ ": " 2020-12-31T23: 00: 00Z \ ", " to \ ": " 2021-12-31T22: 59: 59Z \ "}}}], " must_not \ “: [{” term \ “: {” state.keyword \ ": " merged \ "}}]}}, " size \ ": 0, " aggs \ “: {” time_buckets \ “: {” date_histogram \ “: {” field \ ": " created_at \ ", " interval \ ": " month \ ", " time_zone \ ": " Europe / Rome \ "}}}, " sort \ ": [{\ "updated_at ": {\ "order ": \ "desc "}}, \ " score "]} \ n \ nPayload size: 0M “}”.
When I recreate the indexes with the command: zammad run rake searchindex: rebuild I get this result
rake aborted!
Unable to process GET request to elasticsearch URL ‘http://localhost:9200’. Elasticsearch is not reachable, probably because it’s not running or even installed.
Response:
#<UserAgent::Result:0x000055e66089a5e8 @success=false, @body=nil, @data=nil, @code=0, @content_type=nil, @error="#<Errno::ECONNREFUSED: Failed to open TCP connection to localhost:9200 (Connection refused - connect(2) for “localhost” port 9200)>">
Payload:
null
Payload size: 0M
/opt/zammad/lib/search_index_backend.rb:32:in info' /opt/zammad/lib/tasks/search_index_es.rake:333:in es_version’
/opt/zammad/lib/tasks/search_index_es.rake:343:in es_version_supported?' /opt/zammad/lib/tasks/search_index_es.rake:182:in block (2 levels) in ’
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rake-12.3.3/exe/rake:27:in <top (required)>' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/cli/exec.rb:74:in load’
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/cli/exec.rb:74:in kernel_load' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/cli/exec.rb:28:in run’
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/cli.rb:463:in exec' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/vendor/thor/lib/thor/command.rb:27:in run’
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/vendor/thor/lib/thor/invocation.rb:126:in invoke_command' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/vendor/thor/lib/thor.rb:387:in dispatch’
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/cli.rb:27:in dispatch' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/vendor/thor/lib/thor/base.rb:466:in start’
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/cli.rb:18:in start' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/exe/bundle:30:in block in <top (required)>’
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/friendly_errors.rb:124:in with_friendly_errors' /opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/exe/bundle:22:in <top (required)>’
bin/bundle:3:in load' bin/bundle:3:in ’
Tasks: TOP => searchindex:rebuild => searchindex:version_supported
(See full trace by running task with --trace).
Maybe replace localhost with 127.0.0.1 and try again.
If this does not help, run a simple curl: curl http://localhost:9200.
If it’s not reachable, ensure you don’t have any firewalls fishing away the connections and that your elasticsearch is up and running. Right now it doesn’t look like it is.
