Wrong recipient when answering via mail in Zammad
  • Used Zammad version: 3.0.x
  • Operating system: Linux openSuSE 15.0
  • Browser + version: Microsoft Edge (Canary), Chrome, Firefox, Opera, IE
When answering a ticket via mail the recipient should be the one, who created the ticket (customer).
When answering a ticket (or a response of a ticket), the recipient is always the one who is in the ‘to‘ field of the mail of the created ticket.
e.g.: Forwarding an email as a customer (customer@company.com) to the ticket e-mail address creates a ticket. The recipient is ticket@company.com. Now, when answering that ticket via mail in Zammad the recipient of that email should be customer@company.com but instead Zammad uses the ticket email ticket@company.com.
This issue only occurs (how it seems) on a specific ticket creator mail, which has the same permissions as all the other accounts (agent) and is also setup the same as the others.
Forwarding an email to the ticket mail and replying on that ticket directly in Zammad.
EDIT: It occurs also on other accounts and it only appears when FORWARDING a mail to the ticketsystem to create a ticket.
Heya,
the reason why this does not work is the way a “forward” does work.
If you want to move mails into Zammad you have two options:
  • bouncing the mail (that’s like forwarding, but better with keeping the original header intact, Zammad will work that way)
  • use a subfolder on a mail account Zammad fetches where you move the mail to
Hello guys,
same problem here on moving an email from it-mailbox to zammad-mailbox (collected via POP).
Zammad enters the recipient as the customer… But it should be the sender, shouldn’t it?
By the way: We are testing Zammad 3.1.0 on CentOS 7.6 at the moment.
On our actual KIX-system its working correctly with moving this mails.
Beside recycling old topics might be a bad idea:
Ensure that Zammad knows the E-Mail-Adresse the mail was originally sent to. Otherwise it will literally break upon replying.
