Hey
would you help me again with the problem described below?
thx
Sonja
Used Zammad version: 3.3
Used Zammad installation source: Ubuntu Package
Operating system: Ubuntu 18.4
Browser + version: Firefox 75
When an agent creates a ticket, the subject and customer are transferred as specified by the agent.
As a customer for the ticket, the agent is taken over if the system is set up by telephone. The title is not adopted but only “-” is displayed. Even with some emails, the subject is not correctly adopted, but only “-” is displayed.
By default during ticket creation, no matter if the ticket if a phone or mail tickets, the title is always empty.
Your agent needs to set it. That’s working as designed.
Or you’re talking about splitting. Don’t know.
To the customer thing. I guess you’re talking about the first article not the ticket directly - that sounds like the following “issue”:
opened 03:36PM - 06 Feb 20 UTC
closed 07:26AM - 11 Sep 20 UTC
bug
UX/UI
ticket
verified
prioritised by payment
Please post:
- Feature requests
- Development questions
- Technical questions
### Infos:
* Used Zammad version: 3.2
* Installation method (source, package, ..): any
* Operating system: any
* Database + version: any
* Elasticsearch version: any
* Browser + version: tested on latest Google Chrome and Firefox
* Ticket-ID: #1067678, #1070979, #1073361
### Expected behavior:
* When creating a incoming call ticket Zammad will set the customer you select as "FROM"-Sender in the article allowing you to straightly answer to the user.
* When creating a outgoing call ticket, Zammad will set the customer you select as a "TO" and, when replying to the article, answer the customer straight away.
Above expactations do ignore roles, because you shouldn't have to look for the role a user has. It should be exactly the same behaviour for agents, as this is technically the only way I can communicate with an agent via mail if he needs to be a customer and can't see the ticket in Zamamd for permission reasons.
### Actual behavior:
Below mentioned ticket customers *are agents* but should be able to be a ticket customer in email scope without issue.
* When creating a new incoming call ticket where the ticket customer is an agent, Zammad will set the TO address to the ticket creator when pressing "reply". This is technically correct, but logically not straight forward, as normally the agent would create the ticket on behalf of the user. The users role should be not of a matter here.
*Above actions do work without issues, if the ticket customer is actually a customer and has no agent **rights.*
* When creating a new outgoing call ticket where the ticket customer is an agent, Zammad will not set any TO address when pressing "reply". This is confusing, as Zammad already knows the TO address and should thus fill it in.
*The above does not work for customer users as well, which is a bit unexpected.*
This might be related to earlier issue https://github.com/zammad/zammad/issues/2184
**incoming call ticket**
* ensure the group you'll be creating the ticket in does have a mail address assigned
* create a new "received call" ticket and select any agent user you'd like
* after submitting, press "reply" and check the "TO" field
**outcoing call ticket**
* create a new "outgoing call" ticket and select any users (agent or customer) you'd like
Hello Mr. Generation
I don’t think I described it exactly.
I put z. B. a telephone ticket and assign a customer and title for the ticket.
After creating the ticket, the title is empty and must be set again. I am also the customer of the ticket.
I don’t think that is as it was supposed to be and does not quite meet the problem from the link.wish you a nice evening
I’m sorry, but I can’t reproduce this on hosted and local environments.
This issue might be browser related (possibly addons). You might be able to test if that’s the case by using another browser.
If you still have this issue, please use a trial instance ( https://zammad.com/de/anmeldung ) to ensure it’s not a local instance issue.
If you can’t reproduce this on hosted, by bet would be a trigger that breaks your neck.
I’d recommend blurring the names in the screenshot…
system
Closed
August 28, 2020, 11:14am
6
