how should i do this? i think this is not an html editor. i only format the text with things like
ctrl b oder ctrl i
i have now moved the complete text from zammad to notepad++. then i saved the blank body field. then i copied back the text. i think everything looks good, but why are some words (variables) in blue letters?
Somehow the variable names have been detected as URLs and replaced with a link. I tried to reproduce that, but was not able. You will need to remove the (blue) variable names and replace them with a plain text version.
