Important:
- Used Zammad version: 2.80
- Operating system: Ubuntu 16.04
- Browser + version: Chrome 71.0.3578.98
- I am using the API to create tickets through a form I have created that calls the API using Token Authentication to create an actual ticket.
- I expect that the form will work consistently.
- My form will work for a while from the same browser/tab but, sometimes, I will eventually get an error response with the message “CSRF token validation failure!”.
- Once I get the error the only way to get the form to work again is to either close the browser (all tabs) or, if that did not work, to delete the cookies for the Zammad website.
- Call API from web form to create a ticket multiple times.
- I do sometimes login to the Zammad backend from the browser and my thought is that that may cause the problem but it is not consistent.
