WhatsApp, Phone, SMS Integration with Zammad
We have been using Zammad for the past 5 months for our NGO, and it has been very helpful. Now, we want to extend its usage by integrating WhatsApp, phone calls, and SMS communication channels.
Requirements & Questions
:one: WhatsApp Integration (Meta WhatsApp Cloud API)
  • What are the prerequisites for connecting WhatsApp with Zammad?
  • As an NGO, we are concerned about pricing for the WhatsApp Cloud API. Where can we find accurate and updated information?
  • Can we configure auto-reply messages for customers based on FAQs or simple menu options like:
    • “Press 1 for Product Info”
    • “Press 2 for Support”
  • How does WhatsApp integration work in terms of chatbot-like automation?
:two: Phone Integration with Zammad
  • What is the recommended way to configure phone call support in Zammad?
  • Do we need a SIP provider or any external service?
  • Step-by-step guidance would be really helpful.
:three: SMS Integration
  • How can we enable SMS messaging via Zammad?
  • Are there specific providers or modules required for SMS integration?
:four: Packages, Add-ons, & Usability Enhancements
  • We are running Zammad with Docker Compose.
  • Where can we find the list of available packages, integrations, or extensions to improve Zammad usability?
  • Any recommendations for community-supported or open-source add-ons?
Environment Details
  • Deployment Type: Docker Compose
  • Use Case: NGO Communication (limited budget, non-profit needs)
Request for Help
We are looking for guidance, tutorials, or community suggestions for setting up these integrations smoothly.
I am sorry, but most of your questions are very clearly documented in the Zammad documentation.
Thanks, any link for
zammad packages that we can use?
