Used Zammad version: 3.6.x
Used Zammad installation source: github zammad-docker
Operating system: debian
Browser + version: chrome, Edge
French language uses a lot the apostrophe, My zammad setup does not correctly manage it.
i.e. it displays
“Réduire le nombre ‘d' ’;éléments affichés”
in the tickets.
how to make the interface to correctly show the Apostrophe ?
Hi @virtorgan
make sure that you have the right character encoding enabled on nginx
See this for further info:
HTH,
Martin
Does this issue still appear?
If so, could you provide the string you expect to see here in the forum?
I’ll gladly test in my enviroment.
Sorry for my late reply, yes still appear in Version 3.6.x
I didn’t create any translation myself, just used the French language as my primary language.
then when an email is too big to be seen entirely, I get the “voir plus” link to expand. then when it is expanded I get another link at the end to reduce back.
this line in the translation settings:
but the result in UI is this:
Thank you for your feedback.
This is a bug I already created for you - you can view its state here:
opened 09:00AM - 09 Feb 21 UTC
closed 07:20AM - 11 Feb 21 UTC
UX/UI
ticket
verified
Please post:
- Feature requests
- Development questions
- Technical questions
### Infos:
* Used Zammad version: 3.6 latest (stable as of Friday 5th Feb)
* Installation method (source, package, ..): package
* Operating system: any
* Database + version: any
* Elasticsearch version: any
* Browser + version: verified on Google Chrome v88.0.4324.150
* *Note: This issue originally was discovered by community user virtorgan in [this post](https://community.zammad.org/t/weird-display-for-apostrophe/5797)*
### Expected behavior:
* Zammad will display correct apostrophes when ever needed.
### Actual behavior:
* Apostrophes within the "see more / see less" link on ticket articles are escaped.
* Switch to french
* look at an ticket article that's triggering "see more / see less"
system
Closed
June 9, 2021, 9:02am
6
