- Used Zammad version: 6.4
- Used Zammad installation type: source
- Operating system: ubuntu20.0.4
- Browser + version: google
- The WebSocket connection should work properly and not show the error message “WebSocket connection to ‘wss://0.0.0.0:3000/cable’ failed.”
- When running Zammad in development mode using
dev:https
, the WebSocket connection fails and the mobile app shows the error “The connection to the server was lost.”
The following error appears in the logs:
WebSocket connection to 'wss://0.0.0.0:3000/cable' failed
Ignoring message processed after the WebSocket was closed: "{\"command\":\"message\",\"identifier\":\"{\\\"channel\\\":\\\"GraphqlChannel\\\",\\\"channelId\\\":\\\"19487910784\\\"}\",\"data\":\"...\"}"
Run Zammad in development mode with
dev:https
using the following command:
bash
复制编辑
VITE_RUBY_HOST=0.0.0.0 VITE_RUBY_HTTPS=true RAILS_ENV=development foreman start -f Procfile.dev-https
- Observe that the WebSocket connection to
fails. - Check the mobile app, which shows the error “The connection to the server was lost.”
- Review the logs to see the WebSocket errors.
