Servus Zammad!
- Used Zammad version: 6.3.1-121
- Operating system: Ubuntun 24.04 Server LTS
- Browser + version: Chrome on Linux but same on iPad (not browser related)
- Show sample Webhook code
- Internal Server Error 500, “undefined method `articles’ for nil:NilClass”
zammad-railsserver-1 | I, [2024-09-01T15:21:27.798199#1-150660] INFO -- : Started GET "/api/v1/webhooks/preview?_=1725193643595" for 172.21.0.1 at 2024-09-01 15:21:27 +0200
zammad-railsserver-1 | I, [2024-09-01T15:21:27.804714#1-150660] INFO -- : Processing by WebhooksController#preview as TEXT
zammad-railsserver-1 | I, [2024-09-01T15:21:27.804782#1-150660] INFO -- : Parameters: {"_"=>"1725193643595"}
zammad-railsserver-1 | E, [2024-09-01T15:21:27.845495#1-150660] ERROR -- : undefined method `articles' for nil:NilClass (NoMethodError)
zammad-railsserver-1 | app/controllers/webhooks_controller.rb:11:in `preview'
zammad-railsserver-1 | app/controllers/application_controller/has_download.rb:17:in `block (4 levels) in <module:HasDownload>'
zammad-railsserver-1 | app/controllers/application_controller/has_download.rb:16:in `block (3 levels) in <module:HasDownload>'
zammad-railsserver-1 | app/controllers/application_controller/has_download.rb:15:in `block (2 levels) in <module:HasDownload>'
zammad-railsserver-1 | app/controllers/application_controller/handles_transitions.rb:16:in `handle_transaction'
zammad-railsserver-1 | I, [2024-09-01T15:21:27.849229#1-150660] INFO -- : Completed 500 Internal Server Error in 44ms (Views: 0.2ms | ActiveRecord: 25.3ms | Allocations: 8921)
Might be difficult to reproduce. On a new installation/deployment this did work fine. After some time it started to produce the error. Everything else is working correctly and no other errors are shown in the Log.
Might this be related to the nginx reverse proxy configuration?
I run the setup as docker-compose and have nginx + certbot on the host for SSL termination.
Anyway, as this error sounds more application specific, maybe there are some magic ruby commands which can be executed in the CLI to check the backend.
I hope that this is the only problem and not affecting the normal operation ot Zammad.
Thanks for your hints and guidance!
Cheers,
Bernhard
