xp8it
April 18, 2018, 7:08am
1
I can´t see notification-settings in profile, when logged in as customer. In customer-role the notification-settings is even active.
Notification (Benachrichtigungen) settings should appear in profile-settings
no notification-Settings
Customer-Role:
Customer-Profile-Settings
Hey,
thanks for posting the problem here. As I can see the same problem I am sure that this is a bug.
I opened a issue on the issue tracker and referenced this problem.
opened 11:37AM - 18 Apr 18 UTC
closed 07:27AM - 17 Sep 18 UTC
works as designed / wontfix
notification
personal settings/menu
Please post:
- Feature requests
- Development questions
- Technical questions
### Infos:
* Used Zammad version: 2.3 & 2.4
* Installation method (source, package, ..): package (both)
* Operating system: Ubuntu 16.04 (2.3) & openSuse 43.2 (2.4)
* Database + version: unknown (2.3) & postgreSQL 9.6-1.1 (2.4)
* Elasticsearch version: unknown (2.3) & 5.6.6 (2.4)
* Browser + version: current Edge and Firefox (2.3) & Google Chrome 65.0.3325.181 (2.4)
### Expected behavior:
When setting "notification"-Setting for role "Customers" is set the customer should be able to edit his notification settings under profile.
### Actual behavior:
When setting "notification"-Setting for role "Customers" is set the customer is not able to change nor see his notification settings.
* Go to Settings -> Roles and edit Role "Customers"
* Give the customer the right to edit his notification settings
* login as customer and see that you cannot see the settings
Setting is set:
Customer sees the following options logged in as customer:
Same goes for admins taking a look at zammad as customer:
This Bug/Feature has been postet by xp8it on https://community.zammad.org/t/web-notification-for-customer-role/559
We’ll see if this is really a bug or a feature If you want, I can keep you updated here.
xp8it
May 2, 2018, 8:16am
3
fine, would be nice to receive updates here.
Or can you post a link to the bug-tracker?
Hey,
the issue is still open, I think the devs have other trouble to sort out right now
Link is in my post above.
system
Closed
July 1, 2018, 8:32am
5
Billy
September 17, 2018, 7:28am
6
After discussions with the team, we decided that customers should not be able to view or change their own notification settings. The reason is that there is only a very limited number of options that they can choose from, and that there aren’t many useful use cases where a customer would want to change any of these settings.
