[WCAG] Focus styling for keyboards
https://www.w3.org/WAI/WCAG22/Understanding/focus-appearance.html
Overview listings, breadcrumbs, and icons.
Because Zammad core has disabled it
There is no focus styling on a large proportion of the site. In fact it appears that it has been forceably disabled. Getting something in place isn’t too hard to do, just adding a outline in most cases.
ul.nav-pills a:focus,
a:focus > .menu-item-name,
a.nav-tab:focus,
a.list-button:focus,
.nav-pills.nav-stacked>li>a:focus,
.table-overview tr:focus,
.table-overview tr a:focus,
a.activity-body:focus,
.section a:focus,
a.breadcrumb:focus {
    outline: 1px dashed orange !important;
    outline-color: var(--text-link) !important;
// Also do this for hover states so more obvious
ul.nav-pills a:hover,
a:hover > .menu-item-name,
a.list-button:hover,
.nav-pills.nav-stacked>li>a:hover,
.table-overview tr:hover,
.table-overview tr a:hover
.table-hover>tbody>tr.item:hover,
.table-hover>tbody>tr.item.is-hover {
    outline-color: var(--background-active) !important;
a.nav-tab:hover,
.nav-pills.nav-stacked>li.active>a:hover,
.menu-item:hover {
    outline-color: white !important;
The accessibility will be improved with the new desktop-view.
