Using 'matches regex' in postmaster filter not working
  • Used Zammad version: 6.4.1
  • Used Zammad installation type: (source, package, docker-compose, …) docker-compose
  • Operating system: ubuntu 22.04
  • Browser + version: chrome
  • I am trying to get the matches regex filter on a mail body to work
  • The regex needs to check if 2 ‘words’ are present in the mail body, that the ticked can be assigned to a specific group and add some tags to the ticket.
  • The used regex string is /(?=.*ID:003BCM)(?=.*ID:012FR)/im or /(?=.*ID:003BCM)(?=.*ID:012FR)/s
  • The mail body containes line breaks
  • According to https://rubular.com/ and https://regex101.com/ , the regex strings should work but I cannot get it to work in Zammad
Does Zammad require a specific regex formatting to get this to work?
Best regards
Patrick Vossen
