Denis
1
- Used Zammad version: 7.1.3
- Operating system: debian
- Browser + version: google chrome 151.0.7922.137
- Title of the ticket changes to the value of variable #{last_article.subject}
- Title of the ticket changes to the string " #{last_article / no such object} "
- Add trigger with Execute changes on objects: Ticket - Title - #{last_article.subject}
If I add trigger with Execute changes on objects: Note - Body - #{last_article.subject}, it works as expected.
That makes sense, because articles contain a `subject` attribute, the ticket does not. Tickets only know the `title` attribute.
Side note, Zammad 7.2.2 is the current stable. Especially if your instance is available from the internet, update it now due to CVEs.
Denis
3
Thank you for reply.
This still seems strange to me. Variable “last_article.subject” is defined.
I can use it to set value of article attributes.
I can use it to set email notification parametrs.
But I cannot use it to change value of ticket attribute.
Is there any way to update title of ticket with the value of article attribute?
