Users satisfaction
Hello, first of all sorry if i make some mistakes with my english i try my best.
I was thinking of a way to measure the satisfaction of our users and i was wondering if this could be a future feature.
In my mind i see like a pop-up send to the user when the ticket is closed that ask to rank from 0 to 5 to express his apreciation of the technician’s work.
Thanks for your time and your good work.
Please use the provided template.
Also there should be other feature requests of this kind already I believe.
This is already possible using a combination from triggers, object manager and core workflows:
  • Create a ticket attribute “satisfaction”.
  • Create a core workflow, so that it is only visible once the ticket is closed.
  • Create a core workflow so it cannot be changed, once set.
  • Create a trigger and invite the customer to give a rating, if the ticket is closed. Maybe a scheduler, if you want a delay.
Oh thanks i will try this.
