Upgrading Zammad 3.6.0/Debian 9-Stretch to Zammad 5.0/Debian 10-Buster
  • Used Zammad version: 3.6.0
  • Operating system: Debian 9 Stretch
  • Browser + version: Chrome 95.x
Clean package upgrade zammad 3.6.0/debian 9 to zammad 5.0/debian 10
What things to check before upgrading the whole system ?
Need a little advise before starting …
Is this the right way?
  • Backup the complete system
  • Upgrading debian 9 to latest debian 9
  • Upgrading zammad
  • Debian dist-upgrade
You may want to have 4.0 or 4.1 as step in between on your upgrade path. Just for safety.
Please also ensure that your postgresql is high enough (version wise, see: Software — Zammad documentation).
Apart from that:
Regarding your dist-upgrade:
  • disable and stop Zammad before you do that
  • ensure to have a backup (of course you’ll do! :slight_smile: )
  • check if the dist upgrade also affects your database server - if so, ensure to have a clean data migration in between those versions
after dist-upgrade, please ensure:
Please note that Zammad packages are distribution and version specific.
Skipping above mentioned step will cause you ending in a non functional Zammad installation.
Other than that you should be fine.
