Upgrade Zammad 6.2 to 6.3.1 failed pg_isready
  • Used Zammad version: 6.2.0-1713335465.b27a0d24.centos8
  • Operating system: Rocky Linux 8.10
  • Browser + version: Any
  • Upgrade to 6.3.1-1717174492.3b75df1e.centos8
Preparing : 1/1
Running scriptlet: zammad-6.3.1-1717174492.3b75df1e.centos8.x86_64 1/2
/tmp/tmp.wahOgCXkOk: line 36: pg_isready: command not found
!!! ERROR !!!
Your database does not seem to be online!
Please check your configuration in config/database.yml and ensure the configured database server is online.
  • sudo yum install zammad
Additional info
I have added the bin path to PATH
/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/root/bin:/usr/pgsql-14/bin
pg_isready works when manual testing command
pg_isready (PostgreSQL) 14.12
[xxxx@xxxx tmp]# pg_isready -h localhost -p 5432
localhost:5432 - accepting connections
This issue looks similar to Upgrade Zammad 6.0 to 6.1 failed
Extra information that was missing.
/opt/zammad/config/database.yml
production:
adapter: postgresql
database: zammad
pool: 50
timeout: 5000
encoding: utf8
username: zammad
password: xxxxx
Did anyone else had this issue upgrading to v6.3.1 please?
I have the exact same issue, on AlmaLinux 8.10
Running transaction
  Preparing        :        1/1
  Running scriptlet: zammad-6.3.1-1718095957.bfe18b8e.centos8.x86_64        1/2
/tmp/tmp.ejn9cLGPO1: line 36: pg_isready: command not found
!!! ERROR !!!
Exiting Zammad package installation / upgrade - try again.
error: %prein(zammad-6.3.1-1718095957.bfe18b8e.centos8.x86_64) scriptlet failed, exit status 1
pg_isready is working outside of the script as well:
 pg_isready
/run/postgresql:5432 - accepting connections
database.yml
production:
  adapter: postgresql
  database: zammad
  pool: 50
  timeout: 5000
  encoding: utf8
  username: zammad
  password: ******
Also running PostgreSQL 14.12.
For now I’ve reverted back to a snapshot before the update, installed all updates except Zammad and everything works.
That path looks troubling.
The postinstall script (which is responsible for checking if database is there and then run the migrations etc) is using this path:
PATH=/opt/zammad/bin:/opt/zammad/vendor/bundle/bin:/sbin:/bin:/usr/sbin:/usr/bin:
Officially Rocky and AlmaLinux are not on our supported distribution list (Software — Zammad System Documentation documentation). So in that case you’re technically required to ensure to pick the fitting package version to your distribution and hope it works.
Are these postgresql servers from the default repositories of your distribution or a thirdparty one?
Default repo. I didn’t add anything when installing Zammad.
pgdg-redhat-all.repo
https://download.postgresql.org/pub/repos/yum/common/redhat/rhel-$releasever-$basearch
Thanks for the tip. I have added a symlink and now the installation went through:
sudo ln -s /usr/pgsql-14/bin/pg_isready /usr/bin/pg_isready
I removed it to avoid potential conflicts
sudo /usr/bin/pg_isready
Thanks, this also worked for me. Though your last command should be:
sudo rm /usr/bin/pg_isready
thanks @dragonfly
that worked for us too
Last command has a typo. Should be
Hey,
could someone Explain how to add the Path
i’ve the same Problem Update Zammad 6.2 to 6.3
