- Used Zammad version: 3.4.0-4
- Used Zammad installation source: (source, package, …)
- Operating system: Univention Corporate Server: UCS: 4.4-5 errata710
- Browser + version: Chrome 84.0.4147.125
- during release Upgrade UCS offered an upgrade of the zammad app
- I used UCS standard commands to upgrade (e.g.
univention-app upgrade zammad
) - AFAIK the zammad integration is based on docker-compose
- The upgrade routine hangs in a loop, waiting for the zammad-init container to finish.
waiting for init container to finish install or update...
- I figured out that maybe postgres is involved. The script zammad_20200703152551.configure_host tries to add a zammad user:
... Checking if our PostgreSQL needs some love
... => We need to adjust settings on PostgreSQL
... [Adjusting your PostgreSQL container]
... => Adding Zammad user [PSQL]
psql: FATAL: role "postgres" does not exist
... => Adding superuser with createdb to Zammad user [PSQL]
... => Providing password to Zammad user [PSQL]
... [Okay - enough love for PostgreSQL on this regard]
In the logs of zammad-init container I also see a hint concerning postgres:
/usr/local/bundle/gems/activerecord-5.2.4.3/lib/active_record/model_schema.rb:346:in `attribute_types'
/usr/local/bundle/gems/activerecord-5.2.4.3/lib/active_record/model_schema.rb:370:in `type_for_attribute'
/usr/local/bundle/gems/activerecord-5.2.4.3/lib/active_record/table_metadata.rb:33:in `type'
/usr/local/bundle/gems/activerecord-5.2.4.3/lib/active_record/relation/predicate_builder.rb:51:in `build'
/usr/local/bundle/gems/activerecord-5.2.4.3/lib/active_record/relation/predicate_builder.rb:112:in `block in expand_from_hash'
/usr/local/bundle/gems/activerecord-5.2.4.3/lib/active_record/relation/predicate_builder.rb:71:in `each'
/usr/local/bundle/gems/activerecord-5.2.4.3/lib/active_record/relation/predicate_builder.rb:71:in `flat_map'
/usr/local/bundle/gems/activerecord-5.2.4.3/lib/active_record/relation/predicate_builder.rb:71:in `expand_from_hash'
/usr/local/bundle/gems/activerecord-5.2.4.3/lib/active_record/relation/predicate_builder.rb:21:in `build_from_hash'
/usr/local/bundle/gems/activerecord-5.2.4.3/lib/active_record/relation/where_clause_factory.rb:19:in `build'
/usr/local/bundle/gems/activerecord-5.2.4.3/lib/active_record/relation/query_methods.rb:588:in `where!'
/usr/local/bundle/gems/activerecord-5.2.4.3/lib/active_record/relation/finder_methods.rb:370:in `construct_relation_for_exists'
/usr/local/bundle/gems/activerecord-5.2.4.3/lib/active_record/relation/finder_methods.rb:320:in `exists?'
/usr/local/bundle/gems/activerecord-5.2.4.3/lib/active_record/querying.rb:5:in `exists?'
/opt/zammad/config/initializers/models_searchable.rb:4:in `<main>'
/usr/local/bundle/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:50:in `load'
/usr/local/bundle/gems/activesupport-5.2.4.3/lib/active_support/dependencies.rb:285:in `block in load'
/usr/local/bundle/gems/activesupport-5.2.4.3/lib/active_support/dependencies.rb:257:in `load_dependency'
/usr/local/bundle/gems/activesupport-5.2.4.3/lib/active_support/dependencies.rb:285:in `load'
/usr/local/bundle/gems/railties-5.2.4.3/lib/rails/engine.rb:663:in `block in load_config_initializer'
/usr/local/bundle/gems/activesupport-5.2.4.3/lib/active_support/notifications.rb:170:in `instrument'
/usr/local/bundle/gems/railties-5.2.4.3/lib/rails/engine.rb:662:in `load_config_initializer'
/usr/local/bundle/gems/railties-5.2.4.3/lib/rails/engine.rb:620:in `block (2 levels) in <class:Engine>'
/usr/local/bundle/gems/railties-5.2.4.3/lib/rails/engine.rb:619:in `each'
/usr/local/bundle/gems/railties-5.2.4.3/lib/rails/engine.rb:619:in `block in <class:Engine>'
/usr/local/bundle/gems/railties-5.2.4.3/lib/rails/initializable.rb:32:in `instance_exec'
/usr/local/bundle/gems/railties-5.2.4.3/lib/rails/initializable.rb:32:in `run'
/usr/local/bundle/gems/railties-5.2.4.3/lib/rails/initializable.rb:61:in `block in run_initializers'
/usr/local/bundle/gems/railties-5.2.4.3/lib/rails/initializable.rb:50:in `each'
/usr/local/bundle/gems/railties-5.2.4.3/lib/rails/initializable.rb:50:in `tsort_each_child'
/usr/local/bundle/gems/railties-5.2.4.3/lib/rails/initializable.rb:60:in `run_initializers'
/usr/local/bundle/gems/railties-5.2.4.3/lib/rails/application.rb:361:in `initialize!'
/opt/zammad/config/environment.rb:5:in `<main>'
/usr/local/bundle/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:21:in `require'
/usr/local/bundle/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:21:in `block in require_with_bootsnap_lfi'
/usr/local/bundle/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/loaded_features_index.rb:65:in `register'
/usr/local/bundle/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:20:in `require_with_bootsnap_lfi'
/usr/local/bundle/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:29:in `require'
/usr/local/bundle/gems/activesupport-5.2.4.3/lib/active_support/dependencies.rb:291:in `block in require'
/usr/local/bundle/gems/activesupport-5.2.4.3/lib/active_support/dependencies.rb:291:in `require'
/usr/local/bundle/gems/railties-5.2.4.3/lib/rails/application.rb:337:in `require_environment!'
/usr/local/bundle/gems/railties-5.2.4.3/lib/rails/application.rb:520:in `block in run_tasks_blocks'
/usr/local/bundle/gems/rake-12.3.3/exe/rake:27:in `<top (required)>'
/usr/local/bin/bundle:23:in `load'
/usr/local/bin/bundle:23:in `<main>'
Tasks: TOP => db:create => db:load_config => environment
cannot delete non-empty directory: storage/fs
initialising / updating database...
rake aborted!
PG::ConnectionBad: FATAL: password authentication failed for user "zammad"
Of course, login is not possible, due to unfinished upgrade.
I could not login with psql -U postgres CONTAINER
as well.
