- Used Zammad version: 4.0
- Used Zammad installation source: (source, package, …) Debian
- Operating system: Ubuntu server 16.04
- Browser + version:
not able to search
error when using search
normally if i see this error, i reindex “zammad run rail searchindex:rebuild”
but i got an error after upgrading zammad to 4.0 that 5.6 is not supported,
so i upgarded to 7, now it wont start in the elastic logs i see
java.lang.IllegalStateException: The index [supportdesk_zammad_production_user/WAdCKmlfSZmwXsZATDnWRg] was created with version [5.6.16] but the minimum compatible version is [6.0.0-beta1]. It should be re-indexed in Elasticsearch 6.x before upgrading to 7.12.0.
at org.elasticsearch.cluster.metadata.IndexMetadataVerifier.checkSupportedVersion(IndexMetadataVerifier.java:85) ~[elasticsearch-7.12.0.jar:7.12.0]
at org.elasticsearch.cluster.metadata.IndexMetadataVerifier.verifyIndexMetadata(IndexMetadataVerifier.java:72) ~[elasticsearch-7.12.0.jar:7.12.0]
at org.elasticsearch.gateway.GatewayMetaState.upgradeMetadata(GatewayMetaState.java:235) ~[elasticsearch-7.12.0.jar:7.12.0]
at org.elasticsearch.gateway.GatewayMetaState.upgradeMetadataForNode(GatewayMetaState.java:219) ~[elasticsearch-7.12.0.jar:7.12.0]
at org.elasticsearch.gateway.GatewayMetaState.start(GatewayMetaState.java:150) ~[elasticsearch-7.12.0.jar:7.12.0]
at org.elasticsearch.node.Node.start(Node.java:835) ~[elasticsearch-7.12.0.jar:7.12.0]
at org.elasticsearch.bootstrap.Bootstrap.start(Bootstrap.java:311) ~[elasticsearch-7.12.0.jar:7.12.0]
at org.elasticsearch.bootstrap.Bootstrap.init(Bootstrap.java:406) [elasticsearch-7.12.0.jar:7.12.0]
at org.elasticsearch.bootstrap.Elasticsearch.init(Elasticsearch.java:159) [elasticsearch-7.12.0.jar:7.12.0]
at org.elasticsearch.bootstrap.Elasticsearch.execute(Elasticsearch.java:150) [elasticsearch-7.12.0.jar:7.12.0]
at org.elasticsearch.cli.EnvironmentAwareCommand.execute(EnvironmentAwareCommand.java:75) [elasticsearch-7.12.0.jar:7.12.0]
at org.elasticsearch.cli.Command.mainWithoutErrorHandling(Command.java:116) [elasticsearch-cli-7.12.0.jar:7.12.0]
at org.elasticsearch.cli.Command.main(Command.java:79) [elasticsearch-cli-7.12.0.jar:7.12.0]
at org.elasticsearch.bootstrap.Elasticsearch.main(Elasticsearch.java:115) [elasticsearch-7.12.0.jar:7.12.0]
at org.elasticsearch.bootstrap.Elasticsearch.main(Elasticsearch.java:81) [elasticsearch-7.12.0.jar:7.12.0]
[2021-03-27T06:11:50,865][ERROR][o.e.b.ElasticsearchUncaughtExceptionHandler] [supportdesk] uncaught exception in thread [main]
org.elasticsearch.bootstrap.StartupException: java.lang.IllegalStateException: The index [supportdesk_zammad_production_user/WAdCKmlfSZmwXsZATDnWRg] was created with version [5.6.16] but the minimum compatible version is [6.0.0-beta1]. It should be re-indexed in Elasticsearch 6.x before upgrading to 7.12.0.
at org.elasticsearch.bootstrap.Elasticsearch.init(Elasticsearch.java:163) ~[elasticsearch-7.12.0.jar:7.12.0]
at org.elasticsearch.bootstrap.Elasticsearch.execute(Elasticsearch.java:150) ~[elasticsearch-7.12.0.jar:7.12.0]
at org.elasticsearch.cli.EnvironmentAwareCommand.execute(EnvironmentAwareCommand.java:75) ~[elasticsearch-7.12.0.jar:7.12.0]
at org.elasticsearch.cli.Command.mainWithoutErrorHandling(Command.java:116) ~[elasticsearch-cli-7.12.0.jar:7.12.0]
at org.elasticsearch.cli.Command.main(Command.java:79) ~[elasticsearch-cli-7.12.0.jar:7.12.0]
at org.elasticsearch.bootstrap.Elasticsearch.main(Elasticsearch.java:115) ~[elasticsearch-7.12.0.jar:7.12.0]
at org.elasticsearch.bootstrap.Elasticsearch.main(Elasticsearch.java:81) ~[elasticsearch-7.12.0.jar:7.12.0]
Caused by: java.lang.IllegalStateException: The index [supportdesk_zammad_production_user/WAdCKmlfSZmwXsZATDnWRg] was created with version [5.6.16] but the minimum compatible version is [6.0.0-beta1]. It should be re-indexed in Elasticsearch 6.x before upgrading to 7.12.0.
at org.elasticsearch.bootstrap.Bootstrap.init(Bootstrap.java:406) ~[elasticsearch-7.12.0.jar:7.12.0]
at org.elasticsearch.bootstrap.Elasticsearch.init(Elasticsearch.java:159) ~[elasticsearch-7.12.0.jar:7.12.0]
… 6 more
[2021-03-27T06:11:50,868][INFO ][o.e.n.Node ] [supportdesk] stopping …
[2021-03-27T06:11:50,879][INFO ][o.e.n.Node ] [supportdesk] stopped
[2021-03-27T06:11:50,879][INFO ][o.e.n.Node ] [supportdesk] closing …
[2021-03-27T06:11:50,891][INFO ][o.e.n.Node ] [supportdesk] closed
[2021-03-27T06:11:50,893][INFO ][o.e.x.m.p.NativeController] [supportdesk] Native controller process has stopped - no new native processes can be started
