Upgrade from 6.0.X to 6.1 system is broken
  • Used Zammad version: 6.1.0-1696849338.59fe2e15.jammy
  • Operating system: Ubuntu Jammy
  • running web service
Blockquote
Oct 11 11:22:54 ubuntu-zammad2 systemd[1]: Started zammad-web.service.
Oct 11 11:22:54 ubuntu-zammad2 systemd[1]: Started zammad-web-1.service.
Oct 11 11:22:54 ubuntu-zammad2 zammad-web-1.service[13745]: bundler: failed to load command: script/rails (script/rails)
Oct 11 11:22:54 ubuntu-zammad2 zammad-web-1.service[13745]: /opt/zammad/vendor/bundle/ruby/3.1.0/gems/bootsnap-1.16.0/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:29:in require': cannot load such file -- active_support (LoadError) Oct 11 11:22:54 ubuntu-zammad2 zammad-web-1.service[13745]: #011from /opt/zammad/vendor/bundle/ruby/3.1.0/gems/railties-6.1.7.6/lib/rails/command.rb:3:in
Oct 11 11:22:54 ubuntu-zammad2 zammad-web-1.service[13745]: #011from /opt/zammad/vendor/bundle/ruby/3.1.0/gems/bootsnap-1.16.0/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:32:in require' Oct 11 11:22:54 ubuntu-zammad2 zammad-web-1.service[13745]: #011from /opt/zammad/vendor/bundle/ruby/3.1.0/gems/bootsnap-1.16.0/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:32:in require’
Oct 11 11:22:54 ubuntu-zammad2 zammad-web-1.service[13745]: #011from /opt/zammad/vendor/bundle/ruby/3.1.0/gems/railties-6.1.7.6/lib/rails/commands.rb:3:in <main>' Oct 11 11:22:54 ubuntu-zammad2 zammad-web-1.service[13745]: #011from /opt/zammad/vendor/bundle/ruby/3.1.0/gems/bootsnap-1.16.0/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:32:in require’
Oct 11 11:22:54 ubuntu-zammad2 zammad-web-1.service[13745]: #011from /opt/zammad/vendor/bundle/ruby/3.1.0/gems/bootsnap-1.16.0/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:32:in require' Oct 11 11:22:54 ubuntu-zammad2 zammad-web-1.service[13745]: #011from script/rails:8:in <top (required)>’
Oct 11 11:22:54 ubuntu-zammad2 zammad-web-1.service[13745]: #011from /opt/zammad/vendor/ruby-3.1.3/lib/ruby/3.1.0/bundler/cli/exec.rb:58:in load' Oct 11 11:22:54 ubuntu-zammad2 zammad-web-1.service[13745]: #011from /opt/zammad/vendor/ruby-3.1.3/lib/ruby/3.1.0/bundler/cli/exec.rb:58:in kernel_load’
Oct 11 11:22:54 ubuntu-zammad2 zammad-web-1.service[13745]: #011from /opt/zammad/vendor/ruby-3.1.3/lib/ruby/3.1.0/bundler/cli/exec.rb:23:in run' Oct 11 11:22:54 ubuntu-zammad2 zammad-web-1.service[13745]: #011from /opt/zammad/vendor/ruby-3.1.3/lib/ruby/3.1.0/bundler/cli.rb:486:in exec’
Oct 11 11:22:54 ubuntu-zammad2 zammad-web-1.service[13745]: #011from /opt/zammad/vendor/ruby-3.1.3/lib/ruby/3.1.0/bundler/vendor/thor/lib/thor/command.rb:27:in run' Oct 11 11:22:54 ubuntu-zammad2 zammad-web-1.service[13745]: #011from /opt/zammad/vendor/ruby-3.1.3/lib/ruby/3.1.0/bundler/vendor/thor/lib/thor/invocation.rb:127:in invoke_command’
Oct 11 11:22:54 ubuntu-zammad2 zammad-web-1.service[13745]: #011from /opt/zammad/vendor/ruby-3.1.3/lib/ruby/3.1.0/bundler/vendor/thor/lib/thor.rb:392:in dispatch' Oct 11 11:22:54 ubuntu-zammad2 zammad-web-1.service[13745]: #011from /opt/zammad/vendor/ruby-3.1.3/lib/ruby/3.1.0/bundler/cli.rb:31:in dispatch’
Oct 11 11:22:54 ubuntu-zammad2 zammad-web-1.service[13745]: #011from /opt/zammad/vendor/ruby-3.1.3/lib/ruby/3.1.0/bundler/vendor/thor/lib/thor/base.rb:485:in start' Oct 11 11:22:54 ubuntu-zammad2 zammad-web-1.service[13745]: #011from /opt/zammad/vendor/ruby-3.1.3/lib/ruby/3.1.0/bundler/cli.rb:25:in start’
Oct 11 11:22:54 ubuntu-zammad2 zammad-web-1.service[13745]: #011from /opt/zammad/vendor/ruby-3.1.3/lib/ruby/gems/3.1.0/gems/bundler-2.3.26/libexec/bundle:48:in block in <top (required)>' Oct 11 11:22:54 ubuntu-zammad2 zammad-web-1.service[13745]: #011from /opt/zammad/vendor/ruby-3.1.3/lib/ruby/3.1.0/bundler/friendly_errors.rb:120:in with_friendly_errors’
Oct 11 11:22:54 ubuntu-zammad2 zammad-web-1.service[13745]: #011from /opt/zammad/vendor/ruby-3.1.3/lib/ruby/gems/3.1.0/gems/bundler-2.3.26/libexec/bundle:36:in <top (required)>' Oct 11 11:22:54 ubuntu-zammad2 zammad-web-1.service[13745]: #011from /opt/zammad/bin/bundle:121:in load’
Oct 11 11:22:54 ubuntu-zammad2 zammad-web-1.service[13745]: #011from /opt/zammad/bin/bundle:121:in `’
Oct 11 11:22:54 ubuntu-zammad2 systemd[1]: zammad-web-1.service: Failed with result ‘exit-code’.
Oct 11 11:22:55 ubuntu-zammad2 systemd[1]: zammad-web-1.service: Scheduled restart job, restart counter is at 1.
Oct 11 11:22:55 ubuntu-zammad2 systemd[1]: Stopped zammad-web-1.service.
Oct 11 11:22:55 ubuntu-zammad2 systemd[1]: Started zammad-web-1.service.
  • systemctl stop zammad
  • zammad run rails r “Rails.cache.clear”
  • apt update
  • apt dist-upgrade
I have tried different versions. The latest version which works for me is a downgrade to:
apt install zammad=6.0.0-1692374817.3b8df7cc.jammy
