- Used Zammad version: 4.1 to 5.0.3
- Used Zammad installation type: source
- Operating system: Ubuntu 20.04.3
- Browser + version: Chrome 96+
- expecting to run rake db:migrate successfully
- rake db:migrate fails to execute with duplicate migrations for setting_add_internal_article_check
- Stop Zammad instance
- Create backup
- Switch to zammad user
- Clear Zammad Cache (rails r “Cache.clear”)
- Install new Dependencies (nodejs, Ruby 2.7.4, bundler, rake, rails)
- Update .bashrc default ruby version to use
- switch to root user
- Download stable version of Zammad (wget stable.tar.gz)
- Extract tar to Zammad folder (tar -xzf stable.tar.gz --strip-components 1 -C zammad)
- Change ownership of files (chown -R zammad:zammad zammad/)
- Check that database.yml file has 600 permisiones set and its owned by zammad:zammad
- switch to zammad user
- Run gem install bundler (again, as per instructions)
- Run bundle install --without test development mysql
- Run rake db:migrate (which fails with duplicate migrations)
After I found the error I went to the db/mgrate folder and did an
ls -ltrh | grep internal
and found two (2) files for setting_add_internal_article_check.rb:
Then I went to other folders like: config/initializers and found to other files that seem to be left overs from 4.1 version…
Is it necessary to first upgrade to 5.0 and the apply the update to 5.03? I would appreciate any input on this issue.
Best,
Javier
I see several files that remain from
I ran a find . -mtime +9 to see which files are older than the date from 5.0.3 and found the following files:
./config/pre_commit.yml
./config/initializers/workaround_active_job_time_serialization.rb
./config/initializers/workaround_active_job_logging.rb
./app/assets/javascripts/app/views/generic/ticket_selector.jst.eco
./app/assets/javascripts/app/views/generic/ticket_selector_row.jst.eco
./app/assets/javascripts/app/lib/app_post/ticket_create_collection.coffee
./app/assets/javascripts/app/controllers/agent_ticket_create/form_hander_signature.coffee
./app/assets/javascripts/app/controllers/ticket_zoom/form_handler_dependencies.coffee
./app/assets/javascripts/app/controllers/ticket_zoom/owner_handler_dependencies.coffee
./app/models/concerns/has_knowledge_base_attachment_permissions.rb
./app/models/concerns/has_ticket_create_screen_impact.rb
./app/models/user/has_ticket_create_screen_impact.rb
./app/controllers/application_controller/has_secure_content_security_policy_for_downloads.rb
./app/controllers/sessions
./app/controllers/sessions/collection_base.rb
./app/controllers/sessions/collection_ticket.rb
./app/controllers/sessions/collection_dashboard.rb
./app/jobs/ticket_create_screen_job.rb
./db/migrate/202104070000001_setting_add_internal_article_check.rb
I will retry the upgrade to 5.0.3 manually deleting these files, hope this goes well…
Best,
Javier
system
closed
#3
