- Used Zammad version: 3.6.0-1615986441.da478686.stretch
- Used Zammad installation source: (package)
- Used PostgreSQL version: 9.6
- Operating system: Debian 9
Upgrade via Debian source from 3.6 to 4.0 should work without problems.
However, at the db:migrate step, the installation stops with the following errors.
rake aborted!
StandardError: An error has occurred, this and all later migrations canceled:
Directly inheriting from ActiveRecord::Migration is not supported. Please specify the Rails release the migration was written for:
class UpdateScheduler3 < ActiveRecord::Migration[4.2]
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.5/lib/active_record/migration.rb:528:in `inherited'
/opt/zammad/db/migrate/20131208000001_update_scheduler3.rb:1:in `<main>'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:21:in `require'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:21:in `block in require_with_bootsnap_lfi'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/loaded_features_index.rb:65:in `register'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:20:in `require_with_bootsnap_lfi'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bootsnap-1.3.2/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:29:in `require'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.5/lib/active_support/dependencies.rb:291:in `block in require'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.5/lib/active_support/dependencies.rb:257:in `load_dependency'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activesupport-5.2.4.5/lib/active_support/dependencies.rb:291:in `require'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.5/lib/active_record/migration.rb:986:in `load_migration'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.5/lib/active_record/migration.rb:982:in `migration'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.5/lib/active_record/migration.rb:977:in `disable_ddl_transaction'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.5/lib/active_record/migration.rb:1350:in `use_transaction?'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.5/lib/active_record/migration.rb:1342:in `ddl_transaction'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.5/lib/active_record/migration.rb:1291:in `execute_migration_in_transaction'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.5/lib/active_record/migration.rb:1263:in `block in migrate_without_lock'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.5/lib/active_record/migration.rb:1262:in `each'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.5/lib/active_record/migration.rb:1262:in `migrate_without_lock'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.5/lib/active_record/migration.rb:1210:in `block in migrate'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.5/lib/active_record/migration.rb:1363:in `with_advisory_lock'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.5/lib/active_record/migration.rb:1210:in `migrate'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.5/lib/active_record/migration.rb:1036:in `up'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.5/lib/active_record/migration.rb:1011:in `migrate'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.5/lib/active_record/tasks/database_tasks.rb:172:in `migrate'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/activerecord-5.2.4.5/lib/active_record/railties/databases.rake:60:in `block (2 levels) in <main>'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/rake-12.3.3/exe/rake:27:in `<top (required)>'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/cli/exec.rb:74:in `load'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/cli/exec.rb:74:in `kernel_load'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/cli/exec.rb:28:in `run'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/cli.rb:463:in `exec'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/vendor/thor/lib/thor/command.rb:27:in `run'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/vendor/thor/lib/thor/invocation.rb:126:in `invoke_command'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/vendor/thor/lib/thor.rb:387:in `dispatch'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/cli.rb:27:in `dispatch'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/vendor/thor/lib/thor/base.rb:466:in `start'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/cli.rb:18:in `start'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/exe/bundle:30:in `block in <top (required)>'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/lib/bundler/friendly_errors.rb:124:in `with_friendly_errors'
/opt/zammad/vendor/bundle/ruby/2.6.0/gems/bundler-1.17.3/exe/bundle:22:in `<top (required)>'
Caused by:
StandardError: Directly inheriting from ActiveRecord::Migration is not supported. Please specify the Rails release the migration was written for:
I’m afraid I don’t know. We have a second instance which runs on Debian 10, but everything worked without problems.
Do you have any ideas how I can fix this?
