Upgrade docker from 6.1 to 6.3, nginx waiting for init container to finish
  • Used Zammad version: 6.3.1-196
  • Operating system: vm Debian 12 - Portainer
  • Browser + version:
  • Upgrade from version 6.2.0-1 should run the zammad-nginx container when the zammad-init is finished
  • The containers are upgraded but the container zammad-niginx is waiting for init container to finish…
  • Fist I change the docker-compose.yml with this one
docker-compose.ym for 6.3.1-196
version: '3.8'
x-shared:
  zammad-service: &zammad-service
    environment: &zammad-environment
      MEMCACHE_SERVERS: ${MEMCACHE_SERVERS}
      POSTGRESQL_DB: ${POSTGRES_DB}
      POSTGRESQL_HOST: ${POSTGRES_HOST}
      POSTGRESQL_USER: ${POSTGRES_USER}
      POSTGRESQL_PASS: ${POSTGRES_PASS}
      POSTGRESQL_PORT: ${POSTGRES_PORT}
      POSTGRESQL_OPTIONS: ${POSTGRESQL_OPTIONS}
      POSTGRESQL_DB_CREATE:
      REDIS_URL: ${REDIS_URL}
      # Backup settings
      BACKUP_DIR: "${BACKUP_DIR}"
      BACKUP_TIME: "${BACKUP_TIME}"
      HOLD_DAYS: "${HOLD_DAYS}"
      TZ: "${TZ}"
    image: ${IMAGE_REPO}:${VERSION}
    restart: ${RESTART:-always}
    volumes:
      - /mnt/${NAME_ENV}/${NAME_CLIENT}/${NAME_APP}/zammad-storage:/opt/zammad/storage
    depends_on:
      - zammad-memcached
      - zammad-postgresql
      - zammad-redis
services:
  zammad-backup:
    <<: *zammad-service
    command: ["zammad-backup"]
    volumes:
      - /mnt/${NAME_ENV}/${NAME_CLIENT}/${NAME_APP}/zammad-backup:/var/tmp/zammad
      - /mnt/${NAME_ENV}/${NAME_CLIENT}/${NAME_APP}/zammad-storage:/opt/zammad/storage:ro
    user: 0:0
  zammad-elasticsearch:
    image: bitnami/elasticsearch:${ELASTICSEARCH_VERSION}
    volumes:
      - /mnt/${NAME_ENV}/${NAME_CLIENT}/${NAME_APP}/elasticsearch-data:/bitnami/elasticsearch/data
  zammad-init:
    <<: *zammad-service
    command: ["zammad-init"]
    depends_on:
      - zammad-postgresql
    restart: on-failure
    user: 0:0
  zammad-memcached:
    command: memcached -m 256M
    image: memcached:${MEMCACHE_VERSION}
  zammad-nginx:
    <<: *zammad-service
    command: ["zammad-nginx"][details="docker-compose.ym for 6.3.1-196"]
    expose:
      - "${NGINX_PORT}"
    ports:
      - "${NGINX_EXPOSE_PORT}:${NGINX_PORT}"
    environment:
      NGINX_PORT: ${NGINX_PORT}
      NGINX_SERVER_SCHEME: ${NGINX_SERVER_SCHEME}
      VIRTUAL_HOST: ${VIRTUAL_HOST}
      NGINX_SERVER_NAME: ${NGINX_SERVER_NAME}
      RAILS_TRUSTED_PROXIES: ${RAILS_TRUSTED_PROXIES}
    depends_on:
      - zammad-railsserver
  zammad-postgresql:
    environment:
      POSTGRES_DB: ${POSTGRES_DB}
      POSTGRES_USER: ${POSTGRES_USER}
      POSTGRES_PASSWORD: ${POSTGRES_PASS}
    image: postgres:${POSTGRES_VERSION}
    volumes:
      - /mnt/${NAME_ENV}/${NAME_CLIENT}/${NAME_APP}/postgresql-data:/var/lib/postgresql/data
  zammad-railsserver:
    <<: *zammad-service
    command: ["zammad-railsserver"]
    extra_hosts:
      - "git.numericoop.fr:10.10.10.20"
  zammad-redis:
    image: redis:${REDIS_VERSION}
    volumes:
      - /mnt/${NAME_ENV}/${NAME_CLIENT}/${NAME_APP}/redis-data:/data
  zammad-scheduler:
    <<: *zammad-service
    command: ["zammad-scheduler"]
  zammad-websocket:
    <<: *zammad-service
    command: ["zammad-websocket"
Before I was using this one
docker-compose.ym for 6.2.0-1
version: '3.8'
x-shared:
    restart: ${RESTART}
    volumes:
      - /mnt/${NAME_ENV}/${NAME_CLIENT}/${NAME_APP}/zammad-var:/opt/zammad/var
    depends_on:
      - zammad-memcached
      - zammad-postgresql
      - zammad-redis
services:
  zammad-backup:
    depends_on:
      - zammad-postgresql
    entrypoint: /usr/local/bin/backup.sh
    environment:
      <<: *zammad-environment
      BACKUP_TIME: "23:00"
      HOLD_DAYS: "10"
      TZ: Europe/Paris
    restart: ${RESTART}
    volumes:
      - /mnt/${NAME_ENV}/${NAME_CLIENT}/${NAME_APP}/zammad-var:/opt/zammad/var:ro
      - /mnt/${NAME_ENV}/${NAME_CLIENT}/${NAME_APP}/scripts/backup.sh:/usr/local/bin/backup.sh:ro
    restart: ${RESTART}
    volumes:
  zammad-init:
    <<: *zammad-service
    depends_on:
      - zammad-postgresql
    restart: on-failure
    user: 0:0
    volumes:
  zammad-memcached:
    restart: ${RESTART}
  zammad-nginx:
    <<: *zammad-service
    expose:
      - "$NGINX_PORT"
    ports:
      - "${ENV_NGINX_PORT}:${NGINX_PORT}"
    environment:
    depends_on:
    volumes:
      - /mnt/${NAME_ENV}/${NAME_CLIENT}/${NAME_APP}/zammad-var:/opt/zammad/var:ro # required for the zammad-ready check file
  zammad-postgresql:
    environment:
    restart: ${RESTART}
    volumes:
  zammad-railsserver:
    <<: *zammad-service
    extra_hosts:
  zammad-redis:
    restart: ${RESTART}
    volumes:
  zammad-scheduler:
    <<: *zammad-service
  zammad-websocket:
    <<: *zammad-service
    command: ["zammad-websocket"]
I understand some mount points are no more used for now…
I have try also copy the zammad.conf from the container
docker cp -a stack-zammad-pp-zammad-nginx-1:opt/zammad/contrib/nginx/zammad.conf .
edit this one with correct values with a customize NGINX_PORT and NGINX_EXPOSE_PORT, then it is a reverse-proxy which do the job. I try first on preprod environment where ports are different from production environment…
I put the variables on a env in portainer, is it the problem ?
Then I have try copy the zammad.conf and also have the symbolic link for nginx
docker cp zammad.conf stack-zammad-pp-zammad-nginx-1:/etc/nginx/sites-available/
docker exec -it -u root stack-zammad-pp-zammad-nginx-1 chown 1000:1000 /etc/nginx/sites-available/zammad.conf
docker exec -it -u root stack-zammad-pp-zammad-nginx-1 ln -s /etc/nginx/sites-available/zammad.conf /etc/nginx/sites-enabled/zammad.conf
Then try upgrade from Portainer my code witg the variables edited on the portainer env
But anyway, the container is waiting zammad-init to finish, but the zammad-init have finish his job.
What’s wrong ?
Can I mount the folder /etc/nginx/ to edit the files if necessary ? Or is not recommanded ?
Perhaps it’s not possible do an upgarde from 6.2 to this last patch 6.3.1-196 ??
can someone help me ?
containers logs
docker logs stack-zammad-pp-zammad-nginx-1
waiting for init container to finish install or update...
docker logs stack-zammad-pp-zammad-init-1
initialising / updating database...
Clearing cache...
I, [2025-03-26T17:09:31.279201 #22]  INFO -- : ActionCable is using the redis instance at redis://zammad-redis:6379.
I, [2025-03-26T17:09:31.309736#22-6080]  INFO -- : Using memcached as Rails cache store.
I, [2025-03-26T17:09:31.309962#22-6080]  INFO -- : Using the Redis back end for Zammad's web socket session store.
Executing migrations...
I, [2025-03-26T17:09:37.807686 #30]  INFO -- : ActionCable is using the redis instance at redis://zammad-redis:6379.
I, [2025-03-26T17:09:37.826856#30-6900]  INFO -- : Using memcached as Rails cache store.
I, [2025-03-26T17:09:37.827154#30-6900]  INFO -- : Using the Redis back end for Zammad's web socket session store.
Synchronizing locales...
I, [2025-03-26T17:09:43.502733 #38]  INFO -- : ActionCable is using the redis instance at redis://zammad-redis:6379.
I, [2025-03-26T17:09:43.519072#38-6080]  INFO -- : Using memcached as Rails cache store.
I, [2025-03-26T17:09:43.519302#38-6080]  INFO -- : Using the Redis back end for Zammad's web socket session store.
Synchronizing translations...
I, [2025-03-26T17:09:50.177328 #46]  INFO -- : ActionCable is using the redis instance at redis://zammad-redis:6379.
I, [2025-03-26T17:09:50.192973#46-6080]  INFO -- : Using memcached as Rails cache store.
I, [2025-03-26T17:09:50.193181#46-6080]  INFO -- : Using the Redis back end for Zammad's web socket session store.
changing settings...
I, [2025-03-26T17:10:29.305911 #54]  INFO -- : ActionCable is using the redis instance at redis://zammad-redis:6379.
I, [2025-03-26T17:10:29.321248#54-6080]  INFO -- : Using memcached as Rails cache store.
I, [2025-03-26T17:10:29.321472#54-6080]  INFO -- : Using the Redis back end for Zammad's web socket session store.
I, [2025-03-26T17:10:32.827876#54-6080]  INFO -- : Setting.set('es_url', "http://zammad-elasticsearch:9200")
I, [2025-03-26T17:10:36.034664 #62]  INFO -- : ActionCable is using the redis instance at redis://zammad-redis:6379.
I, [2025-03-26T17:10:36.049835#62-6080]  INFO -- : Using memcached as Rails cache store.
I, [2025-03-26T17:10:36.050031#62-6080]  INFO -- : Using the Redis back end for Zammad's web socket session store.
I, [2025-03-26T17:10:39.956281#62-6080] nano zammad.conf
docker logs stack-zammad-pp-zammad-railsserver-1
starting railsserver... with WEB_CONCURRENCY=0
Puma starting in single mode...
* Puma version: 6.4.3 (ruby 3.2.4-p170) ("The Eagle of Durango")
*  Min threads: 5
*  Max threads: 30
*  Environment: production
*          PID: 1
I, [2025-03-26T16:35:27.862337 #1]  INFO -- : ActionCable is using the redis instance at redis://zammad-redis:6379.
I, [2025-03-26T16:35:27.885763#1-6900]  INFO -- : Using memcached as Rails cache store.
I, [2025-03-26T16:35:27.886191#1-6900]  INFO -- : Using the Redis back end for Zammad's web socket session store.
* Listening on http://[::]:3000
Use Ctrl-C to stop
docker logs stack-zammad-pp-zammad-postgresql-1
PostgreSQL Database directory appears to contain a database; Skipping initialization
2025-03-26 15:34:48.709 UTC [1] LOG:  starting PostgreSQL 15.8 on x86_64-pc-linux-musl, compiled by gcc (Alpine 13.2.1_git20240309) 13.2.1 20240309, 64-bit
2025-03-26 15:34:48.710 UTC [1] LOG:  listening on IPv4 address "0.0.0.0", port 5432
2025-03-26 15:34:48.710 UTC [1] LOG:  listening on IPv6 address "::", port 5432
2025-03-26 15:34:48.776 UTC [1] LOG:  listening on Unix socket "/var/run/postgresql/.s.PGSQL.5432"
2025-03-26 15:34:48.918 UTC [30] LOG:  database system was shut down at 2025-03-26 15:34:23 UTC
2025-03-26 15:34:49.030 UTC [1] LOG:  database system is ready to accept connections
2025-03-26 15:34:49.763 UTC [34] LOG:  incomplete startup packet
2025-03-26 15:39:48.974 UTC [28] LOG:  checkpoint starting: time
2025-03-26 15:39:55.575 UTC [28] LOG:  checkpoint complete: wrote 62 buffers (0.4%); 0 WAL file(s) added, 0 removed, 0 recycled; write=6.142 s, sync=0.222 s, total=6.602 sB
2025-03-26 15:44:48.676 UTC [28] LOG:  checkpoint starting: time
2025-03-26 15:44:49.134 UTC [28] LOG:  checkpoint complete: wrote 3 buffers (0.0%); 0 WAL file(s) added, 0 removed, 0 recycled; write=0.224 s, sync=0.071 s, total=0.459 s;B
2025-03-26 15:49:48.195 UTC [28] LOG:  checkpoint starting: time
2025-03-26 15:49:48.625 UTC [28] LOG:  checkpoint complete: wrote 3 buffers (0.0%); 0 WAL file(s) added, 0 removed, 0 recycled; write=0.221 s, sync=0.044 s, total=0.431 s;B
2025-03-26 15:54:48.721 UTC [28] LOG:  checkpoint starting: time
2025-03-26 15:54:49.370 UTC [28] LOG:  checkpoint complete: wrote 6 buffers (0.0%); 0 WAL file(s) added, 0 removed, 0 recycled; write=0.521 s, sync=0.022 s, total=0.650 s;B
2025-03-26 15:59:48.433 UTC [28] LOG:  checkpoint starting: time
2025-03-26 15:59:49.416 UTC [28] LOG:  checkpoint complete: wrote 8 buffers (0.0%); 0 WAL file(s) added, 0 removed, 0 recycled; write=0.716 s, sync=0.100 s, total=0.983 s;B
2025-03-26 16:04:48.510 UTC [28] LOG:  checkpoint starting: time
2025-03-26 16:04:48.952 UTC [28] LOG:  checkpoint complete: wrote 3 buffers (0.0%); 0 WAL file(s) added, 0 removed, 0 recycled; write=0.227 s, sync=0.065 s, total=0.443 s;B
2025-03-26 16:09:21.096 UTC [118] LOG:  incomplete startup packet
2025-03-26 16:09:49.045 UTC [28] LOG:  checkpoint starting: time
2025-03-26 16:09:49.525 UTC [28] LOG:  checkpoint complete: wrote 3 buffers (0.0%); 0 WAL file(s) added, 0 removed, 0 recycled; write=0.229 s, sync=0.047 s, total=0.480 s;B
2025-03-26 16:14:49.622 UTC [28] LOG:  checkpoint starting: time
2025-03-26 16:14:50.340 UTC [28] LOG:  checkpoint complete: wrote 6 buffers (0.0%); 0 WAL file(s) added, 0 removed, 0 recycled; write=0.526 s, sync=0.053 s, total=0.719 s;B
2025-03-26 16:19:49.403 UTC [28] LOG:  checkpoint starting: time
2025-03-26 16:19:49.834 UTC [28] LOG:  checkpoint complete: wrote 3 buffers (0.0%); 0 WAL file(s) added, 0 removed, 0 recycled; write=0.218 s, sync=0.074 s, total=0.432 s;B
2025-03-26 16:24:49.898 UTC [28] LOG:  checkpoint starting: time
2025-03-26 16:24:50.731 UTC [28] LOG:  checkpoint complete: wrote 6 buffers (0.0%); 0 WAL file(s) added, 0 removed, 0 recycled; write=0.524 s, sync=0.116 s, total=0.833 s;B
2025-03-26 16:29:49.831 UTC [28] LOG:  checkpoint starting: time
2025-03-26 16:29:50.589 UTC [28] LOG:  checkpoint complete: wrote 6 buffers (0.0%); 0 WAL file(s) added, 0 removed, 0 recycled; write=0.535 s, sync=0.059 s, total=0.759 s;B
2025-03-26 16:34:49.688 UTC [28] LOG:  checkpoint starting: time
2025-03-26 16:34:50.078 UTC [28] LOG:  checkpoint complete: wrote 3 buffers (0.0%); 0 WAL file(s) added, 0 removed, 0 recycled; write=0.224 s, sync=0.034 s, total=0.390 s;B
2025-03-26 16:39:49.177 UTC [28] LOG:  checkpoint starting: time
2025-03-26 16:39:49.637 UTC [28] LOG:  checkpoint complete: wrote 3 buffers (0.0%); 0 WAL file(s) added, 0 removed, 0 recycled; write=0.220 s, sync=0.038 s, total=0.460 s;B
2025-03-26 16:44:49.697 UTC [28] LOG:  checkpoint starting: time
2025-03-26 16:44:50.463 UTC [28] LOG:  checkpoint complete: wrote 6 buffers (0.0%); 0 WAL file(s) added, 0 removed, 0 recycled; write=0.523 s, sync=0.072 s, total=0.767 s;B
2025-03-26 16:49:49.561 UTC [28] LOG:  checkpoint starting: time
2025-03-26 16:49:50.124 UTC [28] LOG:  checkpoint complete: wrote 3 buffers (0.0%); 0 WAL file(s) added, 0 removed, 0 recycled; write=0.226 s, sync=0.134 s, total=0.563 s;B
2025-03-26 16:54:49.222 UTC [28] LOG:  checkpoint starting: time
2025-03-26 16:54:49.977 UTC [28] LOG:  checkpoint complete: wrote 6 buffers (0.0%); 0 WAL file(s) added, 0 removed, 0 recycled; write=0.521 s, sync=0.069 s, total=0.755 s;B
2025-03-26 16:59:50.067 UTC [28] LOG:  checkpoint starting: time
2025-03-26 16:59:50.973 UTC [28] LOG:  checkpoint complete: wrote 6 buffers (0.0%); 0 WAL file(s) added, 0 removed, 0 recycled; write=0.531 s, sync=0.132 s, total=0.906 s;B
2025-03-26 17:04:51.062 UTC [28] LOG:  checkpoint starting: time
2025-03-26 17:04:51.500 UTC [28] LOG:  checkpoint complete: wrote 3 buffers (0.0%); 0 WAL file(s) added, 0 removed, 0 recycled; write=0.227 s, sync=0.045 s, total=0.439 s;B
2025-03-26 17:09:51.579 UTC [28] LOG:  checkpoint starting: time
2025-03-26 17:09:52.082 UTC [28] LOG:  checkpoint complete: wrote 3 buffers (0.0%); 0 WAL file(s) added, 0 removed, 0 recycled; write=0.226 s, sync=0.053 s, total=0.503 s;B
docker logs stack-zammad-pp-zammad-websocket-1
starting websocket server...
I, [2025-03-26T16:35:28.802153 #1]  INFO -- : ActionCable is using the redis instance at redis://zammad-redis:6379.
I, [2025-03-26T16:35:28.828034#1-6160]  INFO -- : Using memcached as Rails cache store.
I, [2025-03-26T16:35:28.828386#1-6160]  INFO -- : Using the Redis back end for Zammad's web socket session store.
docker logs stack-zammad-pp-zammad-redis-1
1:C 26 Mar 2025 15:34:48.222 # WARNING Memory overcommit must be enabled! Without it, a background save or replication may fail under low memory condition. Being disabled, it can also cause failur.
1:C 26 Mar 2025 15:34:48.222 * oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
1:C 26 Mar 2025 15:34:48.222 * Redis version=7.4.1, bits=64, commit=00000000, modified=0, pid=1, just started
1:C 26 Mar 2025 15:34:48.222 # Warning: no config file specified, using the default config. In order to specify a config file use redis-server /path/to/redis.conf
1:M 26 Mar 2025 15:34:48.224 * monotonic clock: POSIX clock_gettime
1:M 26 Mar 2025 15:34:48.227 * Running mode=standalone, port=6379.
1:M 26 Mar 2025 15:34:48.229 * Server initialized
1:M 26 Mar 2025 15:34:48.229 * Loading RDB produced by version 7.4.1
1:M 26 Mar 2025 15:34:48.229 * RDB age 26 seconds
1:M 26 Mar 2025 15:34:48.229 * RDB memory usage when created 1.02 Mb
1:M 26 Mar 2025 15:34:48.229 * Done loading RDB, keys loaded: 0, keys expired: 0.
1:M 26 Mar 2025 15:34:48.229 * DB loaded from disk: 0.001 seconds
1:M 26 Mar 2025 15:34:48.229 * Ready to accept connections tcp
docker logs stack-zammad-pp-zammad-scheduler-1
I, [2025-03-26T18:19:32.007275#1-149120]  INFO -- : Running job thread for 'Process ticket escalations.' (Ticket.process_escalation) status is: sleep
I, [2025-03-26T18:19:32.007338#1-149120]  INFO -- : Running job thread for 'Execute planned jobs.' (Job.run) status is: sleep
I, [2025-03-26T18:19:42.009283#1-149120]  INFO -- : ProcessScheduledJobs running...
I, [2025-03-26T18:19:42.011976#1-149120]  INFO -- : Running job thread for 'Check 'Channel' streams.' (Channel.stream) status is: sleep
I, [2025-03-26T18:19:42.012103#1-149120]  INFO -- : Running job thread for 'Generate 'Session' data.' (Sessions.jobs) status is: sleep
I, [2025-03-26T18:19:42.012347#1-149120]  INFO -- : Running job thread for 'Check channels.' (Channel.fetch) status is: sleep
I, [2025-03-26T18:19:42.012453#1-149120]  INFO -- : Running job thread for 'Process ticket escalations.' (Ticket.process_escalation) status is: sleep
I, [2025-03-26T18:19:42.012585#1-149120]  INFO -- : Running job thread for 'Execute planned jobs.' (Job.run) status is: sleep
I, [2025-03-26T18:19:47.602461#1-149180]  INFO -- : execute Channel.fetch (try_count 0)...
I, [2025-03-26T18:19:47.604319#1-149180]  INFO -- : fetching imap (yuno.numericoop.fr/zammadpreprod port=993,ssl=true,starttls=false,folder=INBOX,keep_on_server=false,auth_type=LOGIN)
I, [2025-03-26T18:19:48.008430#1-149180]  INFO -- :  - no message
I, [2025-03-26T18:19:48.027945#1-149180]  INFO -- : ended Channel.fetch took: 0.468875178 seconds.
I, [2025-03-26T18:19:52.014499#1-149120]  INFO -- : ProcessScheduledJobs running...
I, [2025-03-26T18:19:52.016640#1-149120]  INFO -- : Running job thread for 'Check 'Channel' streams.' (Channel.stream) status is: sleep
I, [2025-03-26T18:19:52.016787#1-149120]  INFO -- : Running job thread for 'Generate 'Session' data.' (Sessions.jobs) status is: sleep
I, [2025-03-26T18:19:52.017063#1-149120]  INFO -- : Running job thread for 'Process ticket escalations.' (Ticket.process_escalation) status is: sleep
I, [2025-03-26T18:19:52.017163#1-149120]  INFO -- : Running job thread for 'Check channels.' (Channel.fetch) status is: sleep
I, [2025-03-26T18:19:52.017259#1-149120]  INFO -- : Running job thread for 'Execute planned jobs.' (Job.run) status is: sleep
I, [2025-03-26T18:20:02.019734#1-149120]  INFO -- : ProcessScheduledJobs running...
I, [2025-03-26T18:20:02.022552#1-149120]  INFO -- : Running job thread for 'Check 'Channel' streams.' (Channel.stream) status is: sleep
I, [2025-03-26T18:20:02.022689#1This text will be hidden-149120]  INFO -- : Running job thread for 'Generate 'Session' data.' (Sessions.jobs) status is: sleep
I, [2025-03-26T18:20:02.022972#1-149120]  INFO -- : Running job thread for 'Process ticket escalations.' (Ticket.process_escalation) status is: sleep
I, [2025-03-26T18:20:02.023055#1-149120]  INFO -- : Running job thread for 'Check channels.' (Channel.fetch) status is: sleep
I, [2025-03-26T18:20:02.023133#1-149120]  INFO -- : Running job thread for 'Execute planned jobs.' (Job.run) status is: sleep
I, [2025-03-26T18:20:12.025505#1-149120]  INFO -- : ProcessScheduledJobs running...
I, [2025-03-26T18:20:12.027854#1-149120]  INFO -- : Running job thread for 'Check 'Channel' streams.' (Channel.stream) status is: sleep
I, [2025-03-26T18:20:12.027972#1-149120]  INFO -- : Running job thread for 'Generate 'Session' data.' (Sessions.jobs) status is: sleep
I, [2025-03-26T18:20:12.028249#1-149120]  INFO -- : Running job thread for 'Process ticket escalations.' (Ticket.process_escalation) status is: sleep
I, [2025-03-26T18:20:12.028349#1-149120]  INFO -- : Running job thread for 'Check channels.' (Channel.fetch) status is: sleep
I, [2025-03-26T18:20:12.028418#1-149120]  INFO -- : Running job thread for 'Execute planned jobs.' (Job.run) status is: sleep
I, [2025-03-26T18:20:18.113473#1-149180]  INFO -- : execute Channel.fetch (try_count 0)...
I, [2025-03-26T18:20:18.115982#1-149180]  INFO -- : fetching imap (yuno.numericoop.fr/zammadpreprod port=993,ssl=true,starttls=false,folder=INBOX,keep_on_server=false,auth_type=LOGIN)
I, [2025-03-26T18:20:18.382730#1-149180]  INFO -- :  - no message
I, [2025-03-26T18:20:18.404568#1-149180]  INFO -- : ended Channel.fetch took: 0.375431213 seconds.
docker logs stack-zammad-pp-zammad-elasticsearch-1
[2025-03-26T15:35:42,419][INFO ][o.e.x.s.c.f.PersistentCache] [da278cc0f8d6] persistent cache index loaded
[2025-03-26T15:35:42,420][INFO ][o.e.x.d.l.DeprecationIndexingComponent] [da278cc0f8d6] deprecation component started
[2025-03-26T15:35:42,573][INFO ][o.e.t.TransportService   ] [da278cc0f8d6] publish_address {172.30.0.4:9300}, bound_addresses {0.0.0.0:9300}
[2025-03-26T15:35:43,870][INFO ][o.e.c.c.ClusterBootstrapService] [da278cc0f8d6] this node is locked into cluster UUID [Rmtqd8maS-up-DHpscMduA] and will not attempt further cluster bootstrapping
[2025-03-26T15:35:44,182][INFO ][o.e.c.s.MasterService    ] [da278cc0f8d6] elected-as-master ([1] nodes joined in term 36)[_FINISH_ELECTION_, {da278cc0f8d6}{fz4O13OxSn2w7IC0trNG0Q}{Nco0IsA4RpGrs3U}
[2025-03-26T15:35:44,628][INFO ][o.e.c.s.ClusterApplierService] [da278cc0f8d6] master node changed {previous [], current [{da278cc0f8d6}{fz4O13OxSn2w7IC0trNG0Q}{Nco0IsA4RpGrs3Unt00ejw}{da278cc0f8d}
[2025-03-26T15:35:44,701][INFO ][o.e.c.c.NodeJoinExecutor ] [da278cc0f8d6] node-join: [{da278cc0f8d6}{fz4O13OxSn2w7IC0trNG0Q}{Nco0IsA4RpGrs3Unt00ejw}{da278cc0f8d6}{172.30.0.4}{172.30.0.4:9300}{cdf]
[2025-03-26T15:35:44,712][INFO ][o.e.h.AbstractHttpServerTransport] [da278cc0f8d6] publish_address {172.30.0.4:9200}, bound_addresses {0.0.0.0:9200}
[2025-03-26T15:35:44,742][INFO ][o.e.n.Node               ] [da278cc0f8d6] started {da278cc0f8d6}{fz4O13OxSn2w7IC0trNG0Q}{Nco0IsA4RpGrs3Unt00ejw}{da278cc0f8d6}{172.30.0.4}{172.30.0.4:9300}{cdfhilm}
{"@timestamp":"2025-03-26T15:35:45.726Z", "log.level": "WARN",  "data_stream.dataset":"deprecation.elasticsearch","data_stream.namespace":"default","data_stream.type":"logs","elasticsearch.event.c}
[2025-03-26T15:35:46,113][INFO ][o.e.l.ClusterStateLicenseService] [da278cc0f8d6] license [139c9a25-1309-49e6-b0a1-60caf4cc104f] mode [basic] - valid
[2025-03-26T15:35:46,120][INFO ][o.e.c.f.AbstractFileWatchingService] [da278cc0f8d6] starting file watcher ...
[2025-03-26T15:35:46,130][INFO ][o.e.g.GatewayService     ] [da278cc0f8d6] recovered [15] indices into cluster_state
[2025-03-26T15:35:46,131][INFO ][o.e.c.f.AbstractFileWatchingService] [da278cc0f8d6] file settings service up and running [tid=44]
[2025-03-26T15:35:46,138][INFO ][o.e.r.s.FileSettingsService] [da278cc0f8d6] setting file [/opt/bitnami/elasticsearch/config/operator/settings.json] not found, initializing [file_settings] as empty
[2025-03-26T15:35:49,015][INFO ][o.e.h.n.s.HealthNodeTaskExecutor] [da278cc0f8d6] Node [{da278cc0f8d6}{fz4O13OxSn2w7IC0trNG0Q}] is selected as the current health node.
[2025-03-26T15:35:49,018][ERROR][o.e.i.g.GeoIpDownloader  ] [da278cc0f8d6] exception during geoip databases update org.elasticsearch.ElasticsearchException: not all primary shards of [.geoip_databe
        at org.elasticsearch.ingest.geoip@8.15.2/org.elasticsearch.ingest.geoip.GeoIpDownloader.updateDatabases(GeoIpDownloader.java:141)
        at org.elasticsearch.ingest.geoip@8.15.2/org.elasticsearch.ingest.geoip.GeoIpDownloader.runDownloader(GeoIpDownloader.java:293)
        at org.elasticsearch.ingest.geoip@8.15.2/org.elasticsearch.ingest.geoip.GeoIpDownloaderTaskExecutor.nodeOperation(GeoIpDownloaderTaskExecutor.java:162)
        at org.elasticsearch.ingest.geoip@8.15.2/org.elasticsearch.ingest.geoip.GeoIpDownloaderTaskExecutor.nodeOperation(GeoIpDownloaderTaskExecutor.java:61)
        at org.elasticsearch.server@8.15.2/org.elasticsearch.persistent.NodePersistentTasksExecutor$1.doRun(NodePersistentTasksExecutor.java:34)
        at org.elasticsearch.server@8.15.2/org.elasticsearch.common.util.concurrent.ThreadContext$ContextPreservingAbstractRunnable.doRun(ThreadContext.java:984)
        at org.elasticsearch.server@8.15.2/org.elasticsearch.common.util.concurrent.AbstractRunnable.run(AbstractRunnable.java:26)
        at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1136)
        at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635)
        at java.base/java.lang.Thread.run(Thread.java:840)
[2025-03-26T15:35:49,774][INFO ][o.e.i.g.DatabaseNodeService] [da278cc0f8d6] successfully loaded geoip database file [GeoLite2-Country.mmdb]
[2025-03-26T15:35:49,850][INFO ][o.e.i.g.DatabaseNodeService] [da278cc0f8d6] successfully loaded geoip database file [GeoLite2-ASN.mmdb]
[2025-03-26T15:35:50,829][INFO ][o.e.i.g.DatabaseNodeService] [da278cc0f8d6] successfully loaded geoip database file [GeoLite2-City.mmdb]
[2025-03-26T15:35:57,787][INFO ][o.e.c.r.a.AllocationService] [da278cc0f8d6] current.health="YELLOW" message="Cluster health status changed from [RED] to [YELLOW] (reason: [shards started [[zammad"
mark , i also want to know how to backup or restore after update the zammad (docker-compose)
