SELINUX is disabled on the system. I did another update on another C7 host and it completed successfully so it seems linked to the current implementation of Zammad on the host.
Reinstall 1 Package
Total download size: 236 M
Installed size: 653 M
Is this ok [y/d/N]: y
Downloading packages:
zammad-3.1.0-1570545649.c1160c5e.centos7.x86_64.rpm | 236 MB 00:00:26
Running transaction check
Running transaction test
Transaction test succeeded
Running transaction
Installing : zammad-3.1.0-1570545649.c1160c5e.centos7.x86_64 1/1
# (Re)creating init scripts
Nothing to do.
Nothing to do.
Nothing to do.
# Enabling Zammad on boot
# Stopping Zammad
# Updating translations...
-> removing [ingest-attachment]...
-> Downloading ingest-attachment from elastic
[=================================================] 100%
@ WARNING: plugin requires additional permissions @
* java.lang.RuntimePermission accessClassInPackage.sun.java2d.cmm.kcms
* java.lang.RuntimePermission accessDeclaredMembers
* java.lang.RuntimePermission getClassLoader
* java.lang.reflect.ReflectPermission suppressAccessChecks
* java.security.SecurityPermission createAccessControlContext
* java.security.SecurityPermission insertProvider
* java.security.SecurityPermission putProviderProperty.BC
See http://docs.oracle.com/javase/8/docs/technotes/guides/security/permissions.html
for descriptions of what these permissions allow and the associated risks.
-> Installed ingest-attachment
# Starting Zammad
# Restarting webserver nginx
/etc/nginx/conf.d/zammad.conf and restart nginx process.
Remember to enable selinux and firewall rules!
Use the following commands:
setsebool httpd_can_network_connect on -P
firewall-cmd --zone=public --add-service=http --permanent
firewall-cmd --zone=public --add-service=https --permanent
firewall-cmd --reload
Verifying : zammad-3.1.0-1570545649.c1160c5e.centos7.x86_64 1/1
Installed:
zammad.x86_64 0:3.1.0-1570545649.c1160c5e.centos7
Complete!
