Update error: post-installation script subprocess returned error exit status 1
  • Used Zammad version: 7.0.2-1781669454.9dc15acf.jammy
  • Used Zammad installation type: (source, package, docker-compose, …) Ubuntu package
  • Operating system: Ubuntu 22.04.5 LTS
  • Zammad gets upgraded to 7.1.2-1786027046.fb3abf2.ubuntu22 amd64.
  • dpkg: error processing package zammad (–configure):
    installed zammad package post-installation script subprocess returned error exit status 1
This issue has been solved.
Running “dpkg --configure zammad” again I found “ActiveRecord::RecordInvalid: Validation failed: AI provider is missing”.
The setting ai_provider was configured as true. But there was no specific AI Provider selected. Zammad 7.1 seems to be more rigid there checking the configuration than Zammad 7.0.
We are not using Zammad AI. So I just deactivated it (zammad run rails r “Setting.set(‘ai_provider’, false)”) and everything is fine now.
