Used Zammad version: 3.1.0
Used Zammad installation source: Ubuntu via Deb
Operating system: Ubuntu 18.0.4 with NGINX and Postgre
Browser + version: Safari 13.x, Firefox 69.x
I decided to make some CSS changes, and created a CSS file in relevant custom directory. Proceeded to run the following command for changes to take effect:
zammad run rake precompile:assets
Which gave the output:
/opt/zammad/vendor/bundle/ruby/2.5.0/gems/rake-12.3.2/exe/rake:27:in `<top (required)>'
/opt/zammad/vendor/bundle/ruby/2.5.0/gems/bundler-1.15.2/lib/bundler/cli/exec.rb:74:in `load'
/opt/zammad/vendor/bundle/ruby/2.5.0/gems/bundler-1.15.2/lib/bundler/cli/exec.rb:74:in `kernel_load'
/opt/zammad/vendor/bundle/ruby/2.5.0/gems/bundler-1.15.2/lib/bundler/cli/exec.rb:27:in `run'
/opt/zammad/vendor/bundle/ruby/2.5.0/gems/bundler-1.15.2/lib/bundler/cli.rb:360:in `exec'
/opt/zammad/vendor/bundle/ruby/2.5.0/gems/bundler-1.15.2/lib/bundler/vendor/thor/lib/thor/command.rb:27:in `run'
/opt/zammad/vendor/bundle/ruby/2.5.0/gems/bundler-1.15.2/lib/bundler/vendor/thor/lib/thor/invocation.rb:126:in `invoke_command'
/opt/zammad/vendor/bundle/ruby/2.5.0/gems/bundler-1.15.2/lib/bundler/vendor/thor/lib/thor.rb:369:in `dispatch'
/opt/zammad/vendor/bundle/ruby/2.5.0/gems/bundler-1.15.2/lib/bundler/cli.rb:20:in `dispatch'
/opt/zammad/vendor/bundle/ruby/2.5.0/gems/bundler-1.15.2/lib/bundler/vendor/thor/lib/thor/base.rb:444:in `start'
/opt/zammad/vendor/bundle/ruby/2.5.0/gems/bundler-1.15.2/lib/bundler/cli.rb:10:in `start'
/opt/zammad/vendor/bundle/ruby/2.5.0/gems/bundler-1.15.2/exe/bundle:30:in `block in <top (required)>'
/opt/zammad/vendor/bundle/ruby/2.5.0/gems/bundler-1.15.2/lib/bundler/friendly_errors.rb:121:in `with_friendly_errors'
/opt/zammad/vendor/bundle/ruby/2.5.0/gems/bundler-1.15.2/exe/bundle:22:in `<top (required)>'
The Ruby version mentioned above is 2.5.0.
In the Ubuntu install mentioned in the Documentation we do not install Ruby, rvm etc, like while installing from source.
Yet the folder /opt/zammad/vendor/ruby-2.5.5 exists.
Long story short how do I correct this situation.
Is this the complete traceback? Looks incomplete to me?
Could you run again and please post the complete traceback?
Sorry, should have done this the first time. The entire trace:
rake aborted!
Don't know how to build task 'precompile:assets' (See the list of available tasks with `rake --tasks`)
/opt/zammad/vendor/bundle/ruby/2.5.0/gems/rake-12.3.2/lib/rake/task_manager.rb:59:in `[]'
/opt/zammad/vendor/bundle/ruby/2.5.0/gems/rake-12.3.2/lib/rake/application.rb:159:in `invoke_task'
/opt/zammad/vendor/bundle/ruby/2.5.0/gems/rake-12.3.2/lib/rake/application.rb:116:in `block (2 levels) in top_level'
/opt/zammad/vendor/bundle/ruby/2.5.0/gems/rake-12.3.2/lib/rake/application.rb:116:in `each'
/opt/zammad/vendor/bundle/ruby/2.5.0/gems/rake-12.3.2/lib/rake/application.rb:116:in `block in top_level'
/opt/zammad/vendor/bundle/ruby/2.5.0/gems/rake-12.3.2/lib/rake/application.rb:125:in `run_with_threads'
/opt/zammad/vendor/bundle/ruby/2.5.0/gems/rake-12.3.2/lib/rake/application.rb:110:in `top_level'
/opt/zammad/vendor/bundle/ruby/2.5.0/gems/rake-12.3.2/lib/rake/application.rb:83:in `block in run'
/opt/zammad/vendor/bundle/ruby/2.5.0/gems/rake-12.3.2/lib/rake/application.rb:186:in `standard_exception_handling'
/opt/zammad/vendor/bundle/ruby/2.5.0/gems/rake-12.3.2/lib/rake/application.rb:80:in `run'
/opt/zammad/vendor/bundle/ruby/2.5.0/bin/rake:23:in `load'
/opt/zammad/vendor/bundle/ruby/2.5.0/bin/rake:23:in `<top (required)>'
Doh! I’m really blind.
Don’t know where you got that from, but you might want to try zammad run rails assets:precompile
instead
system
Closed
February 1, 2020, 3:29pm
7
