- Used Zammad version: 2.2
- Used Zammad installation source: (source, package, …) package centos
- Operating system: CENT OS
- Elasicseach 5.6.5 with mapper plugin
- Browser + version: cli
- Index build
Search index will not be build, search tickets or customers does not work, Statsitic does not work.
Behavior after reboot of the server.
Elasticsearch was working in past, after reboot we cant search for Tickes or customers. So we tried to rebuild the index. Elasticsearch and mapper plugins removed and installed again, did not help. Firewall ist open. Even if the firewall is disabled the behavior is the same. It doesnt matter if I Use localhost, fqdn, or, IP Adress.
Unable to process PUT at http://localhost:9200/_ingest/pipeline/zammad-attachment
#<UserAgent::Result:0x0055e4d2cb2c78 @success=false, @body=nil, @data=nil, @code=“400”, @content_type=nil, @error=“Client Error: #<Net::HTTPBadRequest 400 Bad Request readbody=true>!”>
/opt/zammad/lib/search_index_backend.rb:95:inblock (2 levels) in processors' /opt/zammad/lib/search_index_backend.rb:62:ineach’
/opt/zammad/lib/search_index_backend.rb:62:inblock in processors' /opt/zammad/lib/search_index_backend.rb:59:ineach’
/opt/zammad/lib/search_index_backend.rb:59:inprocessors' /opt/zammad/lib/tasks/search_index_es.rake:68:inblock (2 levels) in <top (required)>’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/rake-12.3.0/lib/rake/task.rb:251:inblock in execute' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/rake-12.3.0/lib/rake/task.rb:251:ineach’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/rake-12.3.0/lib/rake/task.rb:251:inexecute' /opt/zammad/lib/tasks/search_index_es.rake:121:inblock (2 levels) in <top (required)>’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/rake-12.3.0/lib/rake/task.rb:251:inexecute' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/rake-12.3.0/lib/rake/task.rb:195:inblock in invoke_with_call_chain’
/opt/zammad/vendor/ruby-2.4.1/lib/ruby/2.4.0/monitor.rb:214:inmon_synchronize' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/rake-12.3.0/lib/rake/task.rb:188:ininvoke_with_call_chain’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/rake-12.3.0/lib/rake/task.rb:181:ininvoke' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/rake-12.3.0/lib/rake/application.rb:160:ininvoke_task’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/rake-12.3.0/lib/rake/application.rb:116:inblock (2 levels) in top_level' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/rake-12.3.0/lib/rake/application.rb:116:ineach’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/rake-12.3.0/lib/rake/application.rb:116:inblock in top_level' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/rake-12.3.0/lib/rake/application.rb:125:inrun_with_threads’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/rake-12.3.0/lib/rake/application.rb:110:intop_level' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/rake-12.3.0/lib/rake/application.rb:83:inblock in run’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/rake-12.3.0/lib/rake/application.rb:186:instandard_exception_handling' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/rake-12.3.0/lib/rake/application.rb:80:inrun’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/rake-12.3.0/exe/rake:27:in<top (required)>' /opt/zammad/vendor/bundle/ruby/2.4.0/bin/rake:22:inload’
/opt/zammad/vendor/bundle/ruby/2.4.0/bin/rake:22:in<top (required)>' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/bundler-1.15.1/lib/bundler/cli/exec.rb:74:inload’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/bundler-1.15.1/lib/bundler/cli/exec.rb:74:inkernel_load' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/bundler-1.15.1/lib/bundler/cli/exec.rb:27:inrun’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/bundler-1.15.1/lib/bundler/cli.rb:360:inexec' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/bundler-1.15.1/lib/bundler/vendor/thor/lib/thor/command.rb:27:inrun’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/bundler-1.15.1/lib/bundler/vendor/thor/lib/thor/invocation.rb:126:ininvoke_command' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/bundler-1.15.1/lib/bundler/vendor/thor/lib/thor.rb:369:indispatch’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/bundler-1.15.1/lib/bundler/cli.rb:20:indispatch' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/bundler-1.15.1/lib/bundler/vendor/thor/lib/thor/base.rb:444:instart’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/bundler-1.15.1/lib/bundler/cli.rb:10:instart' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/bundler-1.15.1/exe/bundle:35:inblock in <top (required)>’
/opt/zammad/vendor/bundle/ruby/2.4.0/gems/bundler-1.15.1/lib/bundler/friendly_errors.rb:121:inwith_friendly_errors' /opt/zammad/vendor/bundle/ruby/2.4.0/gems/bundler-1.15.1/exe/bundle:27:in<top (required)>’
/opt/zammad/bin/bundle:3:inload' /opt/zammad/bin/bundle:3:in’
*zammad run rake searchindex:rebuild --trace
*zammad run rake searchindex:drop --trace
*curl http://localhost:9200
“name” : “fthmWhb”,
“cluster_name” : “elasticsearch”,
“cluster_uuid” : “sqj3B91DT6ujXjnubp7dgw”,
“version” : {
“number” : “5.6.5”,
“build_hash” : “6a37571”,
“build_date” : “2017-12-04T07:50:10.466Z”,
“build_snapshot” : false,
“lucene_version” : “6.6.1”
“tagline” : “You Know, for Search”
Can Anyone please give us a hint?
