Ubuntu 18.04.2 LTS installation
I have some trouble at Ubuntu 18.04.2 LTS - does anybody have an idea for me?
apt-get install zammad
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 zammad : Depends: libimlib2-dev but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
Hi @ChaotY2k ,
according to my sources, this “problem” should be fixed. That apt-get installs the necessary packages. :thinking:
An easy and quick workaround would be, to manually install the dependencies, like describted here:
As OP is already using the install method, I guess something is wrong when trying to solve the dependency for whatever reason.
What happens if you apt-get install libimlib2-dev ?
If that succeeds, try again with apt-get install zammad
root@acocl002:~# apt-get install libimlib2-dev
libimlib2-dev : Depends: libtiff-dev but it is not going to be installed
hmm… it looks like that is not already synched or whatever because i still get that error
I keep on ignoring that your issue template is not complete.
I did a google search for you.
apt-mark showhold to check if your system holds back any affected packages (for whatever reason)
apt-get clean && apt-get update Clean the cache of apt-get and do a friendly refresh of your sources
If this still does not help, post the result of cat /etc/apt/sources.list
Please note that this is a host issue on your end which is not bound to Zammad and likely strike you on several installations with dependencies.
