Looking at the log file, this looks like a duplicate of Don't receive Twitter DMs / railsserver error
The issue should have been fixed in Zammad 3.2.
- did you update from an early version of Zamad to 3.2?
- if yes, did you create the twitter channel the earlier version of Zammad?
- if yes, then try deleting and recreating the channel to possibly pick up the 3.2 fix.
As stated above, I am running Zammad 3.2. Also it is a fresh installation.
Does running the stated commands in the following comment do the trick?
It’s strange that this affects an new installation.
I am still getting the exact same error after running this.
system
closed
#6
