i googled it but didn’t found any informations about it. How is the synthax if i set a trigger and the Title should be searched after different words? Can i take “,” or “;” to seperate the Words?
Thank you for Answers.
Hey @Premyslaw,
sorry for my question but are you really talking about triggers? If so - i kinda don’t get the question.
I assume you’re rather talking about text modules, are you? If so - you can set any title you like and add multiple keywords (separated by a space character [space bar]).
cheers
yes iam talking about Triggers. I want to assign tickets to a special group if the Title contains defined words. Here is a example:
Aaaaah sorry, my bad. I think you simply can’t set multiple conditions there. There already are some feature requests considering this circumstance.
Your only choice probably will be to define multiple triggers.
cheers
Ok thank you for the fast Information!
