Triggers on Telegram tickets
Good day.
Newbie here on Zammad with a prod environment for a small company.
Just wanted to ask about the triggers
Here is the scenario:
  • Trigger is to send an internal email saying a new ticket has been created:
  • When a message is received via email (shared mailbox in O365), this trigger does send the above email
  • When a message is received via Telegram Channel, the trigger does not happen.
Am I missing something or this is the expected behavior?
Thanks in advance for any input.
Regards!
to add this… trigger that sends an email with SLA is close to reach, also not sending when Ticket comes from Telegram Channel, but does work when its created via email
Hm, could it be that tickets coming in through your telegram channel are directly set to open? If that’s not the case: That there’s no sending mail address set for the group? Is the trigger even getting triggered?
I just saw that it was only a misconfigured step.
The telegram Channel tickets go to a particular group that had no email sending
Once i enabled it, i started receiving the email notifications.
Im now receiving 2 emails about the same, so, need to check the config to only receive one
