Is this trigger only applied when all conditions are true?
Is there an Option to set more conditions with an “or” or “and” logical connectiv or I have to create two triggers?
best regards
lobiman
You currently can’t have more than one condition per type, but we have a FR for that:
You can address this with a postmaster filter and a regex (at least that will be an “OR”), but only there!
Regex-Example that does work: ´regex:(bulletin|webinar|summary)
Works it with REGEX when I have to check the “TO” and “CC” field of the Mail?
I didn’t test this but it should as long as you’re within filters
system
Closed
5
