Trigger to "Execute changes on objects" not working for client
  • Used Zammad version: 6.4.0
  • Used Zammad installation type: Docker
  • Operating system: Linux
  • Chrome/Opera
  • WHEN a trigger tries to change a custom field
  • AND it is a client that triggers the trigger via ticket created/updated
  • THEN I expect the field to change
  • The trigger only triggers for my admin user, not clients
  • Create a custom field (in my case, it is a single choice dropdown)
  • Create a trigger for when ticket is created/updated
  • Set this trigger to change the single choice select list
  • Test this as admin (it should change)
  • Test this as a client (it is not updating)
Here is a screenshot to better show the trigger config, and you can also see the field I am trying to set is core one, so this isn’t an issue with custom fields either.
How exactly are you testing this…? Are you just hitting the “update” button and hope for the best…?
Closing, as can no longer replicate, and various too much has changed since January to properly narrow down the cause (eg. security and server updates).
