Tom
September 23, 2020, 11:26am
#1
Used Zammad version: 3.4
Used Zammad installation source: self hosting
Operating system: Linux
Browser + version: Chrome (newest)
Hi!
We are using Zammad, and we use triggers to keep up the notifications.
We want to make some in a different color, so that some things will pop out better. Do anyone have any clue how this is possible?
Thx in advance!
Zammad does not allow you to use coloring in text.
The HTML sanitizer will remove any of these things during sendout or storing to database.
While this may be bad for you, it’s relevant for the sake of the web application to be usuable and visually functioning like the way you know.
You could hack around this issue, but for your own sake, the safety of the Zammad instance and copy cats trying code, I won’t tell you how. I’m sorry.
system
closed
February 5, 2021, 11:06am
#3
