Triggers don’t currently allow a field to be referenced any more than once. Once you select a field, it becomes greyed out when configuring additional conditions. This limits the potential power of triggers. For example, if I want to send an email if the “State” field “has changed”, but only if the state field has been changed to “closed”, I can’t currently do that. I can also think of plenty of use other use cases such as checking if a field “contains” some value but excluding it if it “contains” some other value, or if a field is greater than but less than some value.
Is there a technical reason behind this limitation, or otherwise what is the rationale?
