currently I can’t attach files by any way, with form and inside of zammad cant attach files now. I don’t know if something was changed in the zammad configuration, but before I could attach the files to the ticket.
every time I try to attach a file I get this error and it won’t let me attach [crit] 18#18: *1161 open() “/var/lib/nginx/body/0000000005” failed (13: Permission denied), client: 172.21. 0.1, server: _, request: “POST /api/v1/attachments HTTP/1.0”, host: “xxxxxxxx”, referrer: “xxxxxxxx” if attachments can be created tickets normally, with attachments it does not allow the ticket to be created. Any idea?
I don’t care if it’s “working fine”. According to the first article it isn’t.
Your version is outdated at least for 4 months. Keep your instance updated.
Yes, as mentioned in: Updating Zammad — Zammad System Documentation documentation
However, this documentation part is expecting you have installed it the way it’s documented. If you have adjusted anything in between, then you’ll have to find another way.
