When running a search we run into the issue that a specific Ticket is not indexed. We tested to rebuild the index but still the Ticket is not (re)added to the search.
Used Zammad version: 6.4.1
Used Zammad installation type: Package
Operating system: Debian GNU/Linux 11 (bullseye)
Elasticsearch Version 7.10.2
PostgreSQL 13.18 (Debian 13.18-0+deb11u1)
Browser + version: Chrome Version 131.0.6778.140 (Official Build) (arm64)
When searching all tickets should be accessible / indexed via ticket number and title
The ticket can be accessed via URL: https://zammad.x/#ticket/zoom/3016 but for this ticket content don’t show up in the search.
The ticket is quite extensive: multiple messages and has multiple .pdf attached in various replies. Could this lead to index issues?
All toher tickets are correctly shown in Zammad search.
the following commands have already been executed:
We did rebuild the index: sudo zammad run rake zammad:searchindex:rebuild[8] --trace
Does anybody have a suggestion what to check? Thanks!
Based on other posts, I tried: sudo zammad run rails r "p Ticket.find(3016).search_index_update_backend
Where others return true, this one spits out a long array with a base64 encoded element and payload size: 168M
Could the size of the ticket just be too big to get indexed? And what would be the way forward
MUU4MUMxRDkyQTdGRj5dPj4NCnN0YXJ0eHJlZg0KMTE2DQolJUVPRg0K"}]}]}
Payload size: 168M
from /opt/zammad/lib/search_index_backend.rb:151:in `add'
from /opt/zammad/app/models/concerns/has_search_index_backend.rb:154:in `search_index_update_backend'
from /opt/zammad/vendor/bundle/ruby/3.2.0/gems/railties-7.1.4.1/lib/rails/commands/runner/runner_command.rb:46:in `<main>'
from /opt/zammad/vendor/bundle/ruby/3.2.0/gems/railties-7.1.4.1/lib/rails/commands/runner/runner_command.rb:46:in `eval'
from /opt/zammad/vendor/bundle/ruby/3.2.0/gems/railties-7.1.4.1/lib/rails/commands/runner/runner_command.rb:46:in `block in perform'
from /opt/zammad/vendor/bundle/ruby/3.2.0/gems/activesupport-7.1.4.1/lib/active_support/execution_wrapper.rb:92:in `wrap'
from /opt/zammad/vendor/bundle/ruby/3.2.0/gems/railties-7.1.4.1/lib/rails/commands/runner/runner_command.rb:45:in `perform'
from /opt/zammad/vendor/bundle/ruby/3.2.0/gems/thor-1.3.2/lib/thor/command.rb:28:in `run'
from /opt/zammad/vendor/bundle/ruby/3.2.0/gems/thor-1.3.2/lib/thor/invocation.rb:127:in `invoke_command'
from /opt/zammad/vendor/bundle/ruby/3.2.0/gems/railties-7.1.4.1/lib/rails/command/base.rb:178:in `invoke_command'
from /opt/zammad/vendor/bundle/ruby/3.2.0/gems/thor-1.3.2/lib/thor.rb:538:in `dispatch'
from /opt/zammad/vendor/bundle/ruby/3.2.0/gems/railties-7.1.4.1/lib/rails/command/base.rb:73:in `perform'
from /opt/zammad/vendor/bundle/ruby/3.2.0/gems/railties-7.1.4.1/lib/rails/command.rb:71:in `block in invoke'
from /opt/zammad/vendor/bundle/ruby/3.2.0/gems/railties-7.1.4.1/lib/rails/command.rb:149:in `with_argv'
from /opt/zammad/vendor/bundle/ruby/3.2.0/gems/railties-7.1.4.1/lib/rails/command.rb:69:in `invoke'
from /opt/zammad/vendor/bundle/ruby/3.2.0/gems/railties-7.1.4.1/lib/rails/commands.rb:18:in `<main>'
from <internal:/opt/zammad/vendor/ruby-3.2.4/lib/ruby/3.2.0/rubygems/core_ext/kernel_require.rb>:38:in `require'
from /opt/zammad/vendor/bundle/ruby/3.2.0/gems/bootsnap-1.18.4/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:30:in `require'
from /opt/zammad/bin/rails:4:in `<main>'
Hard to tell what the actual problem is, the error message usually also contains the response from ES. So yes, it’s possible that you haven’t adjusted your ES as suggested by our documentation, you might want to check:
