Used Zammad version: 2.7
Used Zammad installation source: (source, package, …) source
Operating system: debian
Browser + version: any
The imported ticket should have the configured timestamp
The imported ticket has the current timestamp
Create a ticket with a timestamp which is in the past
You will see that the timestamp is ignored. Instead the ticket timestamp will be the current timestamp
That actually works as designed (as far as I know).
You will see that Outlook (on IMAP and POP3) and Exchange will normally do the same (they set the received date, but I might be outdated here).
Zammad sets the fetched date, personally I don’t think that this is bad, since otherwise SLAs might turn bad before you imported the Mails (for whatever reason).
