Ticket fields are readonly for users with secondary organizations on tickets created by another user
  • Used Zammad version: 5.2.x
  • Used Zammad installation type: Source
  • Operating system: Ubuntu 20.04.1 LTS
  • Browser + version: Firefox 104.0.1, Chrome 104.0.5112.102
  • As a customer with secondary organizations and shared organization enabled, i expect to be able to edit ticket fields on tickets created by another user.
  • If a user with customer role tries to edit a ticket belonging to the secondary organization and is created by another user the status field is greyed out.
  1. Make sure the user have customer role and have access to a secondary organization with shared organization enabled.
  2. Create a ticket with another user
  3. Try to change status on the ticket with the user from step 1.
Hi, I think this is an expected behavior.
If 2 user share the same Primary Organization, they can edit each other Tickets like editing the status for example.
If a user has a secondary Organization, her will only have read right to the tickets.
So the user can leave a note but can not change the status or any other ticket field.
Thanks for your reply,
however i would think the expected behavior would be to follow the same ruleset as for the primary organization. Thus be able to edit the Status on a another users tickets.
But i really appreciate you for commenting on my post.
Best regards
I asked developers about this as I feel the same way @chan feels.
Primary and secondary organizations are supposed to behave the exact same way.
This means custom objects shall not be readonly only just because you’re with a secondary organization.
Above statement expects this happening on vanilla installations without core workflows or similar adjusting the availability of a field.
If that’s the case for you, please create a bug report at Issues · zammad/zammad · GitHub and mention this thread so the verification process is faster. Thank you!
Thank you for you reply.
I have reported this in below issue
Best regards
