We need the version of the product for our ticket registration. The version number differs per customer, their version number is available via an API with a unique key per organization.
For the key I have created a custom object on the organization, for the ticket I have created an object with an external data source, I want to use the key in the URL. But no matter what I do, it won’t work.
Can anyone point me in the right direction?
Thanks!
Hi @PeterDijkhuizen. Maybe this and/or this helps.
Hi @fliebe92 I the editor it works #{search.term} but instead of the #{search.term} I want to use the organization object #{organization.custom_key}.
I see the value of the custom_key on the organization page of the ticket and when I copy/paste it into the field it also works, but I want to skip that manual step.
You did not read the documentation entirely
Maybe #{ticket.organization.custom_key} is working.
That works! Before it shows any data I need to give the field any input, like an space or something like that, is there way to workaround that?
Not sure if I got that correctly, but IMO there is no way around it. You need to trigger the search to get some results.
Thank you! I will look into the triggers maybe I can get to work with that.
