Hi! Please help … I can not get the telegram to work. I connected and registered telegram bot according to the instructions. But I can’t figure out what URL should be set to the bot in the webhook settings. All the options I tried return 404. The production log says ERROR no route.
Hi @sviridoff. Please use the template to describe your issue, thanks
In addition to this, please, make sure that your http_type
and fqdn
are correct.
