- Used Zammad version: 6.3.1
- Operating system: Ubuntu 22.04
- Browser + version: Chrome 126.0.6478.127
After the Update to Version 6.3.1 Zammad does not load the System Monitoring Site. All other functionalities seem to work just fine, only the system health site is stuck at loading
- Zammad should load the System Monitoring site
- Stuck at loading
Trying to acces the API Health site:
Logs:
I, [2024-07-07T15:45:29.261303#407540-149900] INFO -- : Processing by MonitoringController#health_check as JSON
I, [2024-07-07T15:45:29.261321#407540-149900] INFO -- : Parameters: {"_"=>"1720366471439"}
E, [2024-07-07T15:45:29.279898#407540-149900] ERROR -- : PG::UndefinedTable: ERROR: relation "failed_emails" does not exist
LINE 9: WHERE a.attrelid = '"failed_emails"'::regclass
(ActiveRecord::StatementInvalid)
lib/monitoring_helper/health_checker/failed_email.rb:8:in `run_health_check'
lib/monitoring_helper/health_checker/backend.rb:13:in `check_health'
lib/monitoring_helper/health_checker.rb:13:in `block in check_health'
lib/monitoring_helper/health_checker.rb:12:in `check_health'
app/controllers/monitoring_controller.rb:34:in `health_check'
app/controllers/application_controller/has_download.rb:17:in `block (4 levels) in <module:HasDownload>'
app/controllers/application_controller/has_download.rb:16:in `block (3 levels) in <module:HasDownload>'
app/controllers/application_controller/has_download.rb:15:in `block (2 levels) in <module:HasDownload>'
I, [2024-07-07T15:45:29.281543#407540-149900] INFO -- : Completed 422 Unprocessable Entity in 20ms (Views: 0.1ms | ActiveRecord: 6.6ms | Allocations: 12080)`````
