i got the following Problem with some of our System Mail Adresses (MDM for Example). If they send a Information to our Helpdesk E-Mail Adress to inform us about events, a Ticket will be created which is correct.
Now i created a Trigger for our Customers, that they get a Mail that that a Ticket was created and closed. That works fine so far.
But now my Problem: The Mails from out System will be send from a smtp-relay and i get a Mailer Daemon Error. Can i filter this System Mail Adresses in one Trigger?
No, that won’t solve your problem.
Domain is for organizations so it will ignore the E-Mail domain.
Actually you could create an custom object (User-Object) like “autoreply” which is by default set to yes.
You add the clause autoreply is not no to your autoreply trigger and then change the user account in question from autoreply=yes to autoreply=no and the problem should be solved.
